Thats why you only use -20*F wiper fluid. I ususally look up the SDS before buying it. The cheap -20*F is literally just water and methanol / methyl alcohol. Its a decent substitute for an intercooler, but works even better with one.Petros wrote: ↑Tue Nov 30, 2021 10:24 pm I see, so it was not the wiper fluid from the windshield reservoir, but rather you were using wiper fluid injection as an intake coolant. That is an interesting solution. I had not heard of anyone using wiper fluid as a turbo coolant, it seems to me there is some soapy component to wiper fluid that I would not want going into the intake. Most all I have heard was an alcohol and water mix. But I have not kept current with what people are doing on street mods. I was complete confused by your description, now it makes sense.
Water injection has been around for a long time, first used as I recall on WW2 turbocharge aircraft engines. It would become another system to install and sort out. Perhaps the simplest way to prevent detonation on a retrofit turbo installation.
Turbo Tercel
- SirFoxx
Re: Turbo Tercel
1985 4wd Tercel SR5 (RIP)
