Question about blower motor...
T-Bone
Post by T-Bone »
I was wondering how hard it is to remove the blower motor for the ac/heat. The SR5 that I am picking up had a mouse make a nest in it so I have to remove it and clean it out.
Lateer
Post by Lateer »
It's not too hard, although you have to remove the glove box to do it.
Once you've removed that, the blower motor for the heating system is easily accesible.
The only problem will be finding the correct size brushes for it. That was the problem I had last time...
1983 Tercel SR5 with 185/75R14 tyres, 32/36 DGAV Weber carburetor, lumpy cam and upgraded Pioneer sound system. Veteran of several fire seasons (with the scars to show it) and known as "The Racing Turtle"
T-Bone
Post by T-Bone »
thanks for the reply. do you know what size of bolts or screws hold the motor in?
2wagons
Post by 2wagons »
I have replaced the brushes a couple of times in my blower motor. I seem to remember that the last time, I realized one might be able to remove the bottom of the blower motor and remove the brushes w/o removing the squirrel cage?
dug320
Post by dug320 »
Brushes?
Never gone through brushes. Bearings, yes.
You can pull the motor without pulling the hole unit. I think it is easier to the pull the whole thing.
