annoying hesitation with carb replacement
I have been meaning to do a detailed carb overhaul but decided to try out some of the extra used carbs I have sitting around to save time. my original carb was leaking fuel out the secondary diaphragm, and also becomes hard to start when it is cold, sometimes requiring starter fluid when it is blow freezing.
but I have a collection of used carbs I have picked up from parts cars, picknpull and elsewhere, I thought I would try those first. I have three with almost identical vac ports and other external features, one looked like it was rebuilt recently, it was all clean and shinny, so I thought I would give that one a try.
I works well except for the noted hesitation. it starts right up, runs well cold, and has a nice power flow from low speed to high speed. Generally a big improvement.
but there is one annoying issue, it will have a hiccup, or brief hesitation when slowly accelerating from a low speed part throttle condition. oddly, no such problem if I just mash the throttle down. it only occurs when slightly slowing or going steady low speed, and than slowly accelerate. a few seconds into the slight acceleration it hiccups once, and than continues to accelerate. It is especially annoying in stop and go traffic, fortuantly I can avoid that where I live most of the time.
one other minor issue that may or may not be related, during warm up when its in fast idle, it will slightly surge idle speed (like there is a slight vacuum leak). it does not happen after it is warmed up. I doubled checked all the vac tubes and routing, all appears good.
I was thinking it is almost like the fuel cut off solenoid is sticking right at the low speed transition area. On hard acceleration the low speed jets are not affected, but only when at low speed, just above idle, and slowly accelerating there is a point where the solenoid must allow fuel flow to avoid a flat spot.
Anyone have any other ideas? what should I check?
If it is easy to fix, I will do so. Otherwise I may just swap out one of the other carbs if I become annoyed with the hiccups.
Re: annoying hesitation with carb replacement
Hey Peter,
Since it’s driveable, I would run some fuel additive carb cleaner and put some miles on it. Hopefully it will clear up for you.
I have the same hesitation as Petros, but it's not so minor. Any sort of movement into the middle of the throttle's travel will cause the engine to stumble unless you back off, or push through to full throttle. Especially scary when trying to make a left turn against traffic.
I have recently rebuilt my carb and suspect that some of the linkages are out of their adjustment spec.
Any help would be a godsend as this issue really affects my enjoyment of this vehicle.
the carb has an idle fuel jet (that was adjustable until the factory capped it off), and there are intermediate fuel and air jets, and the normal full power/full speed jets, that meter fuel and mixes air bubbles into the fuel before it goes into the venturi.
But it appears these intermediate speed fuel jets (only flowing fuel at part throttle) for some reason are getting starved of fuel during transition. could be a blocked passage (crud, corrosion, deposits, something), or perhaps the fuel metering rod (that controls fuel flow) is hanging up, or just stuck on one position.
I do not think there is anyway to fix it unless you take it apart. But Chris's idea of adding the fuel system cleaner is a worth a try, can't hurt, may even work.
there is one other iteml that can affect the fuel flow, and that is that vac operated device on the fender well behind the coolant recovery tank, that adjust low/intermediate mixture by allowing bleed air under the throttle. if it malfunction usually you get poor fuel economy, but it may also result in fuel starvation. it only operates at low/intermediate speeds, so it too is suspect.
unfortunately you can not just cut it out of the system, the carb was designed to work with that device working. I do not think that is my problem, because my old, leaky, dirty carb did not have that, it only happened when I put another carb on my engine that was sitting in my garage in a box for over 5 years. Each day I drive it the hiccup seems less severe, but I may be just getting used to it. It may eventually free itself up without any effort, except perhaps adding the carb cleaner.
Mine seems to be getting worse, not better. I guess I'll just have to go back though the entire troubleshooting process on this carb. Sigh...
I have been meaning to go back and read though the FSM for the operation of the fuel system and the emissions systems. anything that is designed to engage at part throttle condition would be suspect, and that will help narrow it down on what to check.
Some more investigation as I've been driving the car more during the last week:
In the throttle pedal as I move it through the travel I notice there is a "step" in the movement that corresponds to the throttle position the engine stumbles at. This isn't a binding feeling, but more like the carb linkage has contacted another part of the throttle linkage. I was thinking it was about to open the secondary, but aren't those vacuum operated, not mechanical?
yes, there is diaphragm that actuates the secondary throttle, but there is other linkage you might be feeling. there is linkage for the choke so it is forced open when you open the throttle so it does not die out when accelerating above idle.
mine does not seem to be getting any better, though it does not seem to occur when it is cold, when the choke is engages. So it appears that it is because the mixture is too lean right at the transition from idle, to low speed jets.
Petros, have you made any progress diagnosing this issue?
I tried a few things, I do not remember what now. none worked. I was driving it with the hesitation, and the head gasket failed without warning. so I have parked it, and now driving the back up car, a 19 year old civic. I have some other engine issues anyway, so I decided to pull the engine and overbore it to install oversized pistons. It has piston slap. I will likely get to it later this winter.
I might try another carburator when I get it back together, or try to rebuild my old one that did not have the hesitation.
I miss driving it, particularly when I go up to go skiing.
I think head gaskets hate you, Petros.
- Mark
Maybe unrelated, but I just had a similar issue with my '81 Tercel. A couple of years ago, I had switched the distributor vacuum advance from ported to manifold. My idea was that, spending so much time in city traffic, the timing advance would be more beneficial at idle instead of part throttle condition. The problem was, as I accelerated, there was a brief time when the timing would retard (verified with a timing light) as the vacuum reduced and before the centrifugal advance kicked in. Driveability-wise this created a slight lag in acceleration from idle at a certain throttle position. Yesterday, I switched back to ported vacuum advance and the acceleration from idle is much smoother. My distributor only has one vacuum port, but in models with 2 or 3, a defective diaphragm for the ported advance might create some of the same symptoms.
