yes! i totally agree that this is one of the best upgrades. so simple but very useful, at least in rainy climates. i did the same thing on my ae95 shortly after i got it.SynthDesign wrote:I just drove 30 minutes for the 1st time using the intermittent wipers in mixed rain. Wonderful. I think I'm going to have to add this to the must have upgrade list.
Intermittent Wipers..
Re: Intermittent Wipers..
Can the intermittent wiper switch be swapped from tercel to tercel?
95 Camry Wagon, 170k
97 4runner, 275k
97 4runner, 275k
Yes they can. They all have the same plugs.
Alright, I have two, one from Dan and one I pulled this weekend out of an 84, that I wanted to swap in to Pokey and Party!
97 4runner, 275k
97 4runner, 275k
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Anyone have an extra one for a car with Cruise Control? Mine doesn't function in "Int" mode, but works for all the other settings.
- Gottolovem
Not for a cruse control car but if you end up pulling the cruse off i might have one
Does anyone know if the combination switches are the same from 84-89 pickups or can you just use the ones from 4-runners for this mod?
the pickups and 4runners use the same combo switches but you still have to make sure they have the A06 switch. i found it was a toss up as to which kind of switch they had, even though they looked the stalks and hazard light look the same.
So,
As I look a little more, I assume the A10 plugs DO NOT include intermittent wipers. The A06 is needed, more like this?
https://www.ebay.com/itm/254132277601
I'm not sure about A10 plugs but A11 ones have a separate small plug for the adjustable intermittent wiper feature. It was in the photos I posted on the second page of this thread but Photobucket has kindly blurred all my pics because they keep trying to find ways to squeeze a few more $$$ out of people. Anyway, A06 are the ones you want so yes, the ones in that auction are correct.
Hey dlb,
I may go try to pull one of these units off an 87' truck, can you tell me if that steering wheel will take the same size/thread of bolt as the Tercels? I guess I could take some smaller diameter with washers and nuts that I could make work, but it would be nice to have the correct size.
Sorry Chris, it's been a long time so I can't say for sure but I do believe it was the same size nut that holds the steering wheel on the trucks as the tercel. It was big, either 19 or 21 mm I think.
Dlb,
I was asking about the threaded portion of the steering wheel that lets you get a puller on it, usually 0.25”x20 or so, but surely metric for Toyota.
Oh I don't know about that. I never used a puller, just pushed and pulled each side a few times. They take some oomph to do it but not that much.
I think it's 10mm x 1.25
