1984 Trukcel!
- My tercel:: '84 Truckcel 4wd
1984 Trukcel!
Just acquired this bad sally and can't wait to put some serious work into 'er!
Re: 1984 Trukcel!
Welcome to Tercel4wd.com! I hope to finish with a similar paint job on my “good” tercel in the future, I haven’t even started that project.
Re: 1984 Trukcel!
Welcome to the forum!
that is a really interesting rig, nicely done. where are you located?
do you know who did the work on it? please, more pictures, particularly the details on how it was done.
- splatterdog
Re: 1984 Trukcel!
Terchero! I bet it turns heads.
Re: 1984 Trukcel!
Love the paint scheme!
Re: 1984 Trukcel!
Looks awesome. Can you post more pictures?
- My tercel:: 84' tercel sr5 4wd supercharged, 87' Tercel4wd 4age RTR Rallycross
Re: 1984 Trukcel!
Awesome! I thought about going the trukcel route with my rally tercel. Almost exactly what I envisioned!
-Chard
- Mattel
Re: 1984 Trukcel!
Looks great. love the colours. Here's some others.. I love how the french one uses the hatch and glass!
- LowBuckCanuck
Re: 1984 Trukcel!
if I ever come across a tercel that has been partially crushed by a tree, I am sooo gonna make a sweet ute.
Re: 1984 Trukcel!
Hah, that French rig is dope!
I honestly haven't done anything to this rig yet, it was given to me in the state pictured and it needs a LOT of love.
I just started rebuilding the front end and need some help choosing parts.
So far I have ordered:
Timken wheel bearings for all 4 wheels
Superpro Front Sway Bar Bushings and Front Lower Control Arm Bushings
Need some assistance with the front suspension though.
I found the KYB 363037 shocks but I was hoping to lift the front end an inch or two to match the rear, any suggestions?
How about spring and strut replacements? Is there a strut kit from another car that fits? Thanks for your time!
Here are some more pics
Re: 1984 Trukcel!
Iggzmon,
I swapped to Moog 81043 springs in front and stayed with stock struts, love it. I run the Pathfinder springs on the rear and have approximately 2” lift or so over stock.
viewtopic.php?f=2&t=12919&p=108019&hilit=81043#p108019
Re: 1984 Trukcel!
easiest way to raise the front is put shims on top of the upper strut mount (requires longer mounting bolts). Some have used inexpensive HDPE cutting board from wal-mart to make the shim.
the more you raise it the faster your front CV joints will wear out, the larger angle will cause more wear with each revolution of the wheel. ideally longest CV joint life will occur when there is zero angle across the joint when in driving condition. a small amount of lift will not harm it much, but the higher you go the faster those front axles will need to be replaced.
- Mattel
Re: 1984 Trukcel!
spacing the engine, transmission and subframe is what is done on some of the Subarus (such as the professors) will also give you more body clearance and allow larger wheels which can give you more chance to get more clearance under the diffs
Re: 1984 Trukcel!
Rad!! Did you need to modify the spring seats at all to run the https://www.amazon.com/Moog-81043-Coil- ... B0035R28M8's? Just want to confirm before I place ordersNWMO wrote: Mon Oct 28, 2019 9:39 pm Iggzmon,
Re: 1984 Trukcel!
Igg,
I think the 81043 is pigtail vs stock square end, but no. I just installed them on the stock struts and bolted back on.
