sudden dying at stop now and then
I have tried two different carb's on a tercel. the car dies when you come to a stop about one out of ten stops. the bottom just falls out of the idle. i thought it might be the primary fuel cut solenoid not getting voltage, like faulty wiring or something so i rigged it directly to battery and it did not help. anyone else ever have this problem? when it does not die it idles very well.
Abletobecain
Re: sudden dying at stop now and then
Post by Abletobecain »
I have the same problem but for me the idle drops out at every stop and even gear shift when the clutch is held in too long. However, about half the time it idles perfect though. It's really been a bugger trying to figure it out.
Hey all,
I can't say I am having that problem, but my car will often times idle 1,000 rpm or more, but when I come off from highway driving and come to a stop, it may idle down to 700-800 and sound like it is going to die. I tried adjusting the low idle setting per the FSM, but it didn't help.
I have had this problem on several different Tercels I was fixing up, and my daily driver once as well. in every case the problem corrected by adjusting the stop screw on the throttle dampener device on the front of the carb on that end of the throttle shaft (the side opposite the bell crank). it is not obvious why this causes it, but adjusting it makes it go away. it is part of the emissions control system, perhaps the idle is too lean not to have this device, I do not recall what it is called.
It is a vac pot and linkage that slows the closing of the throttle, it is supposed to prevent the throttle plate from slamming shut, and reducing emissions. it is generally a harmless device, but if the stop is out of adjustment it will allow the idle to drop too low when you let off the throttle.
the adjustment is simple, you rev the engine up and release the throttle plat, it should take about 3 seconds for the throttle to come to the idle position. the vac device and linkage hold it open right at the end of its travel and brings it down slowly. there is a FSM procedure to adjust it.
if you have the stop screw too far in it takes too long for the engine to return to idle, it makes shifting gears troublesome. if it is not enough, it will cause the idle to drop below normal, and either stall there, or almost stall, and than slowly return back to the nominal idle speed.
Press2
My tercel:: 86' Tercel 4WD AUS
Post by Press2 »
I've had the same issue with multiple AISIN carbs as per your original post. Tried 3AC and 4AC aisin carbs, both slightly different.
The fix? Ended up replacing my carby with a Holley 5200 and cleaning up the wiring in engine bay to battery.
In my instance i believe I was losing spark when coming to a complete stop due to poor wiring.
Cheers.
slow car 86' Toyota Tercel 4WD
fast car MK6 Golf R
always on jack stands car E36 325i Drift Build
Abletobecain
Petros...I messed with that screw and it definitely changed my idle. I noticed the TP wasn't moving though...applied vacuum to it manually and it held fine. Pulled and tested the TVSV and sure enough it's bad.
Now to find a good one that doesn't cost $50.
