where is the charcoal canister located 4WD wagon ?
Dumindu
Post by Dumindu » Fri Jun 28, 2019 4:11 pm
My car is a 1987 Toyota Tercel DX Wagon RHD 1452cc manual driven car.
1. Where is the charcoal canister located in my car?
2. What happens if the charcoal canister is deleted?
Re: where is the charcoal canister located 4WD wagon ?
Post by irowiki » Fri Jun 28, 2019 10:50 pm
It's behind the Carb, if you're looking at the engine bay from the top, it'd be top left.
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Post by Petros » Sat Jun 29, 2019 6:56 pm
if someone removed it from your car, it should run okay without it as long as your fuel tank is vented. its only function is to prevent fuel vapors from leaking into the air, without it the vapors vent to the atmosphere like all cars used to before required emission controls.
Dumindu
Post by Dumindu » Sat Jun 29, 2019 8:48 pm
Can deleting the charcoal canister result a 4 km/liter fuel mieage in a hot day and when only 2 leters of petrol in the tank ?
Post by Petros » Sat Jun 29, 2019 10:25 pm
I do not think so, but the tank does need to be vented. if not, in hot weather the engine will flood from pressurized fuel tank (resulting in poor economy).
Also, look for vac leaks, and that your AAP diaphragm is not leaking fuel.
Dumindu
Post by Dumindu » Sun Jun 30, 2019 8:28 am
Thank you very much for your valuable advice.
I am having poor fuel economy for couple of days. No leak could found even with the UV dye test. No leak could found in the petrol pump (towards the engine). Carburetor fuel economy seems good with separate bottle line.
Petrol tank lid rubber seal is distorted with gas pressure. Previously such thing couldnt observe. When open the lid there is a "shhh" noice.
Post by irowiki » Sun Jun 30, 2019 10:40 am
If it is really hot the fuel economy will go down the drain on these old cars.
Dumindu
Post by Dumindu » Sun Jun 30, 2019 7:39 pm
What are the sites at which fuel tank ventilation happens in Tercel 4WD wagon?
Post by irowiki » Mon Jul 01, 2019 12:06 am
Three lines coming from the fuel tank, fuel to fuel pump, fuel from fuel pump back to fuel tank, and a line to the charcoal canister.
Dumindu
Post by Dumindu » Mon Jul 01, 2019 10:58 am
From which sites of these lines, the ventilation (check valve) happens/located?
Post by NWMO » Mon Jul 01, 2019 12:43 pm
Dumindu,
If I'm not mistaken, the tank vents through the charcoal canister and I don't believe there is a check valve, just an open line from the tank, through the canister.
