1999 4runner
1999 4runner
Post by irowiki » Thu Feb 14, 2019 12:24 pm
So dad picked up a beat up 1999 4runner, and we completely redid the front end, control arm, tie rods, cv axles, etc. New tires!
Then he decided he doesn't want to deal with all the little issues on a vehicle with 270k miles.
Like the rear window just randomly going down at any time including highway speed :lol: (Unplugging the control module on the rear hatch fixed that for now). I can't even figure out why you'd want the window to go down when you could just open the hatch, just one more thing to go wrong!
He wants to sell it to me cheap. Anyone had experiences with these? Looks like it'd be a capable off roader to do some exploring around southern colorado with.
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Hteverow
My tercel:: 1986 SR5
Re: 1999 4runner
Post by Hteverow » Thu Feb 14, 2019 12:28 pm
Looks like these guys might know a thing or two:
https://www.toyota-4runner.org/3rd-gen- ... 4822f82678
Re: 1999 4runner
Post by irowiki » Thu Feb 14, 2019 12:34 pm
Ah interesting! I was going to wander over to TN as well, but I'll check there too.
The number of model specific forums has been going down in recent years (Like there's no longer a Camry forum outside of TN)
Re: 1999 4runner
Post by Petros » Thu Feb 14, 2019 5:44 pm
no matter the age or condition, 4runners go for big bucks on the west coast. it is like a cult, they go nuts over them, and spend way too much. The price you chose should be between buyer and seller, and what is resonable in the local market.
Since it is a family member, you might get it for a deal, and when it come times to sell it, offer to split what you get over your price when you sell it later.
LowBuckCanuck
Re: 1999 4runner
Post by LowBuckCanuck » Thu Feb 14, 2019 7:34 pm
Check the rear diff breather. Always rusts shut, always blows out the axle seals, and then makes you wonder why your rear drums have oil in them.
Had that happen in a 2001 tacoma, then my friend's 1999 4runner did the exact same thing. It's a common and annoying little issue.
atoyta
My tercel:: 3 wagons now
Re: 1999 4runner
Post by atoyta » Thu Feb 14, 2019 8:40 pm
Another good site for Toyota https://board.marlincrawler.com/index.php None of the Toyotas of that era get great gas mileage & are somewhat under powered .
I have a 90 4runner with 390,000 on it & still working fine. Which engine does it have?
Re: 1999 4runner
Post by irowiki » Fri Feb 15, 2019 11:10 am
I'm not sure what he bought it for but he put a few thousand in parts in it just for the front end plus timing belt kit and new tires and he wants to sell it to me for $1,000. We were thinking the same thing, if we resell it, we'd split the difference after repairs.
Our main issue with buying it, is we have two cars and the RV and not much space for a 4th vehicle!
It probably just needs an entire replacement hatch from a junkyard, someone drilled a bunch of holes in this one and the window regulator is shot.
AHA! That's one of the "pressing issues", the rear axle seals are bad, leaking oil, and the rear brakes are shot.
To be honest, no idea. I'll find out.
LowBuckCanuck
Re: 1999 4runner
Post by LowBuckCanuck » Fri Feb 15, 2019 12:03 pm
Usually people that do stream crossings and whatnot will relocate the differential breather(s) with tubes into the cab.
This removes the chance for water to get into your axles, and subsequently makes it unlikely to rust shut.
Or, you can get it working again, then remember to crawl under every few months and give 'er a jiggle to make sure it stays free
LowBuckCanuck
Re: 1999 4runner
Post by LowBuckCanuck » Fri Feb 15, 2019 12:06 pm
Also, you most likely have the legendary 5vz-fe v6. Damn good engine. Even better supercharged ;)
Re: 1999 4runner
Post by irowiki » Fri Feb 15, 2019 12:11 pm
Ah definitely has the V6 instead of the i4. We took her for a drive and the 4runner pulls better than our 1MZ V6 wagon!
Also has the rear diff lock.
Re: 1999 4runner
Post by Petros » Fri Feb 15, 2019 3:57 pm
that is a bargain, hard to pass up. you will just have to get a larger home and yard, there is no other solution.
atoyta
Re: 1999 4runner
Post by atoyta » Fri Feb 15, 2019 4:39 pm
The 3.4l v/6 is a much better engine than the 3.0
LowBuckCanuck
Re: 1999 4runner
Post by LowBuckCanuck » Sat Feb 16, 2019 8:28 am
The 3.4 is a damn good engine, forged internals and lots of nice aluminum bits. Only thing to make it perfect would be a timing chain instead of a belt, but you can't always get what you want.
The 3.0 gets a bad rap though, if you get around its couple issues it can last as long as a 22r.
