Help...... Front End Noise
Hmmm.... Strut or CV-joint? Is there ANY other time this happens?
The rack bushing on that side will make a clicking noise mostly when going over rougher ground at low speeds....this is the bushing inside the end of the rack. Have to loosen the inside clamp on the boot and check for sideways play.
With the manual rack it's a metal bushing and good old Toyota wants around $22 for it...they sold me a plastic one that didn't fit...it was around $7?
Mine only has about .003" play in it, but makes a knocking noise off road on rough ground in warm weather. Can use some axle grease on the rack under the boot to help this some...doesn't fix it though.
If you are clear down to metal on metal....that would be it. Need to make sure that the threaded end of the bar is not worn too much...otherwise it's a matter of replacing the bushing set on the ends of the bar....there is a writeup on this...
I am getting something similar now. I did the struts last night, and now get a clunking sound out of the front right wheel when I go over bumps. I'll update again tonight.
I love this car.
My girlfriend went to OSU (Oregon State) and is a big-time Beaver Fan. GO BEAVS! Anyhoo, I want to paint the car a different color, but it would need to match the tan plaid interior. She recommended painting it Beaver Orange with black trim. Any thoughts on the easiest and cheapest way to do that without having it look like kaka?
I love this car.
Make sure the top spring perch (strut mount) is tightened properly and slid down on the top of the strut piston properly. I had the same noise when I did my struts, and it turned out that my top strut mount had not seated properly on top of the piston and was banging up and down when pressure was momentarly relieved from it.coltarms wrote: I am getting something similar now. I did the struts last night, and now get a clunking sound out of the front right wheel when I go over bumps. I'll update again tonight.
I love this car.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
