85 SR5 parting out
- Rednecklawrence
- My tercel:: 5.5 Tercels total... Not enough
85 SR5 parting out
Finally getting around to dismantling the green wagon I crashed to get the parts I want. I'll be keeping the drivetrain, doors and probably windows, with other odds and ends, but if you might need anything let me know and I'll see what I can do!
- BaileySims
Re: 85 SR5 parting out
I'm interested in the wiper switch, especially if it has adjustable intermittent wipers. Also looking for the large, double-din factory stereo. Does it still have the inclinometer?
- splatterdog
Front corner lights?
The passenger window weatherstripping
- Rednecklawrence
It was blue, but most of it has been uncovered/wet/repurposed already. Plastics are black I think?
I've got 3 SR5's, none of which have had an inclinometer... And none of them have good/original stereos. It does have this wiper switch though.The Professor wrote: ↑Tue Aug 28, 2018 7:56 am I'm interested in the wiper switch, especially if it has adjustable intermittent wipers. Also looking for the large, double-din factory stereo. Does it still have the inclinometer?
Gone, one sold and the other destroyed. I have a set, but I'm keeping them for another one, should I need them, sorry
I'll have to look into that. Not exactly sure what I'm looking for there. And it's raining outside now haha
If that wiper switch works and sprays fluid, I'll take it!
- Rednecklawrence
It worked before I crashed. It didn't get hit in the crash, so it should still be good. Ill take it out and have a look at it. Just the switch, nothing else?The Professor wrote: ↑Thu Aug 30, 2018 8:35 am If that wiper switch works and sprays fluid, I'll take it!
- splatterdog
Figured it would be a longshot. Look like another winter with an amber 194 bulb and lot's of terminal grease..
Nothing else unless you have:Rednecklawrence wrote: ↑Thu Aug 30, 2018 8:57 amIt worked before I crashed. It didn't get hit in the crash, so it should still be good. Ill take it out and have a look at it. Just the switch, nothing else?The Professor wrote: ↑Thu Aug 30, 2018 8:35 am If that wiper switch works and sprays fluid, I'll take it!
Nice blue front seat belts
adjustable intermittent wiper stalk
double din stereo
complete cruise control assembly
I'd be interested in the harmonic balancer if it's up for grabs?
- Rednecklawrence
The wiper has the whole stalk as far as I'm concerned, and it worked before the crash. I just started school so it's been a little busy. I might be able to get around to that tonight.The Professor wrote: ↑Fri Aug 31, 2018 7:56 amNothing else unless you have:Rednecklawrence wrote: ↑Thu Aug 30, 2018 8:57 amIt worked before I crashed. It didn't get hit in the crash, so it should still be good. Ill take it out and have a look at it. Just the switch, nothing else?The Professor wrote: ↑Thu Aug 30, 2018 8:35 am If that wiper switch works and sprays fluid, I'll take it!
double din stereo
That's the pulley that comes off the crank, right?
Indeed. Where would you be located? I'm over in Spokanistan
- Rednecklawrence
- My tercel:: 1988 toyota sr5 4wd 6sp, weber carb
im looking for an input shaft, is yours still good?
