you will have to make your own front bumper, that one in the pic was something offered as a dealer installed option in Germany only, likely locally made and supplied. doubt there are any survivors this late in the game. They likely did not sell many either.
I would be happy with a set of Euro or Japaneses bumpers, nice and slim profile and lighter. we get stuck with the idiotic federal bumpers, which have proven to be a big mistake (minor repairs are more costly than with standard bumpers, and those big bumpers cause severe injuries to pedestrians in accidents).
new member ..85 sr5
Re: new member ..85 sr5
- My tercel:: 1985 bone stock
Today’s progress .tmm I will try to bolt the trans mount and start it .it was getting late already
Well today I finished installing everything.i still got the ac compressor off I want to install new orings.i got to put the axles back .and speed sensor .it took a long time connecting everything back . I take my time too . There is a blue plug that has nipples for vacuum lines . They broke off . I just connected them together so they won’t be no vacuum leaks .i need to know how much gear oil does the transmission take because a lot of drained out when I removed the engine . Here is the only pics I took today
the trans holds 4.1 quarts of gear oil. makes sure it is fully topped up or severe damage to the trans will result. I use the front fill plug on the side of the diff housing near the CV axle. make sure it is level, and you get it it completely full.
Petros.thank you again for saving me lol im going just to. Drain the whole transmission out first and then top it off . Thanks btw
Well today I installed the cv axles I pour 4 liters into the transmission and also connected the shifter assembly and I tried to start it but it didn’t .it just kept huffing and puffing our the carb . I didn’t know that the distributor had to go a certain way . So I was already tired and it was raining so tmm I’ll make sure I doit right and make sure all the vacuum hoses are right well here is the pic of the day
yea it did ..i barely drive it ...is really fun to drive specially making sharp turns lol
