rear tailshaft housing seal & tranny fluid flush
Re: rear tailshaft housing seal & tranny fluid flush
the spilled gear oil had less to do with what i was using and more to do with this being my first time ever doing a trans flush. and had i been smarter at the time, i would have taken a clean 4 L oil jug, cut the bottom off of it, threaded the hose extension onto it, and used that as a funnel. that's what i did the second time around and it worked great.
So I got my new seal yesterday, and put the Tercel up on jacks to attack the Job.
But I became a little unsure about the real origin of the oil leak...
it looks like there is oil coming from the rear seal, but then again...
Up in front of the tailshaft housing, it is very oily also, around where the 4wd selector lever go's into the GB.
what do you think?
Is there a seal there that could be leaking lots of oil out like this?
there is oil all dripping from the whole underbelly, this is the right hand side passenger foot-well.
I got the new seal in and had it all put back together in an hour. pretty good going I reckon.
the new seal went in pretty easy, I was able to push it all the way in just with my thumb, almost all the way, just about 2 mm left to tap in with the hammer.
maybe because my GB was still hot, and the new seal was not.
the tail shaft bolts near the uni were easy to undo, Just put the Hand Brake on nice and tight, and then undo the nut.
Trying to do it with two spanners without the Hand Brake on was too hard, and I was ending up stripping the bolt head. (made worse because I didn't have two spanners the rights size, one was a shifting spanner...)
the uni joints seemed nice and tight still.
I think the 4WD selector shaft going into the trans leaks on most of our cars. I took a clue from takza's remedy and wrapped the area leading into the trans tightly with twine. That stopped most of it. It can be fixed, but most easily with the trans out of the car.
Unless the seal is totally shot (and the shaft wobbles around in its hole), I would not think that would be the source of the oil you show - that's a lot!
- My tercel:: 1985 tercel 4wd
Actually my 4wd selector shaft seal leaked a little bit for a long time and then became a gusher in a very short period of time.ARCHINSTL wrote:I think the 4WD selector shaft going into the trans leaks on most of our cars. I took a clue from takza's remedy and wrapped the area leading into the trans tightly with twine. That stopped most of it. It can be fixed, but most easily with the trans out of the car.
I was on the road and got lucky and found a tech at a Toyota dealership that was very familiar with our cars. It cost me a little over $100 for the seal and labor. I was happy to pay it, no way it was an easy job with the tranny assy in the car.
A-HA!
Thanks for pointing that out! Another place to keep an eye on!
- My tercel:: 1986 SR5 4WD
I strongly recommend rolling around on a creeper and using that lil pump at least once.. trust me - you will FOR SURE invent a better way for your next flush!
http://www.cardomain.com/ride/3921818/1986-toyota-
*1986 Toyota Tercel SR5* again!
1999 Toyota 4Runner SR5
1990 Jeep Wrangler
http://s164.photobucket.com/albums/u11/ ... cel%204WD/
1990 Jeep Wrangler
- My tercel:: 83 4WD Tercel SR5 - The Brown Badger
Does anyone have any tips for getting the output shaft dust shield off? I am having a hell of a time. It looks like there might be a little rust between the shield and the trans. I have sprayed it down with PB blaster, used a hammer, preyed with a screwdriver, used heat, etc., but NO LUCK. It doesn't help that my CAT had the air tube running right past this area.
It just slips off, there is nothing holding it on but friction. If it has corrosion holding than the only thing you can do is beat it off with a soft hammer. Try soaking in ATF (auto trans fluid), it works well on corroded parts, better than anything else known to the human race in fact.
After soaking in ATF you might make a wood "chisel" and alternately pound it off first on one side than the other. that should work it loose. Try to push it straight back evenly from both sides. If it gets "cocked" it will bind even worse.
good luck.
good luck.
When you are dealing with an aluminum to steel corrosion issue I would suggest that you clean up the area with denatured alcohol to get as much of the oil off as possible. Then use household ammonia directly on the corroded area.BrownBadger wrote:Does anyone have any tips for getting the output shaft dust shield off? I am having a hell of a time. It looks like there might be a little rust between the shield and the trans. I have sprayed it down with PB blaster, used a hammer, preyed with a screwdriver, used heat, etc., but NO LUCK. It doesn't help that my CAT had the air tube running right past this area.
It is an old bicycle mechanic's trick to aid in removing an aluminum seat post that is frozen in a steel frame.
As an old bicycle mechanic - I agree!4wdchico wrote:When you are dealing with an aluminum to steel corrosion issue I would suggest that you clean up the area with denatured alcohol to get as much of the oil off as possible. Then use household ammonia directly on the corroded area.BrownBadger wrote:Does anyone have any tips for getting the output shaft dust shield off? I am having a hell of a time. It looks like there might be a little rust between the shield and the trans. I have sprayed it down with PB blaster, used a hammer, preyed with a screwdriver, used heat, etc., but NO LUCK. It doesn't help that my CAT had the air tube running right past this area.
We used to run into this frequently way back when - particularly on BMX frames.
Tried the ammonia, still no luck. Next step is to try some high head gas. After that I have an idea which might get it off but ruin the shield in the process. Does anybody have a spare dust shield sitting around they would be willing to send me if I do bugger it up?
