I got another toy
Re: I got another toy
What would a smaller carb do?
smaller carb improves low end performance, likely increase torque, also should improve part throttle economy as well. It moves the peak of the power curve down the rpm range, you usually sacrifice max hp, but if you do not running up that high very much anyway (like a drag racer might), the smaller carb is better for all around driveablity.
one of the reasons I am fairly happy with the small stock Tercel carb, the 3ac does not take well to much teaking for more power anyway.
- Gottolovem
After getting it home and doing a little research, the elderbrock carb is 600cfm nearly twice what it should be for a 3.7 v6!
I'm putting a two barrel back on it ASAP
I drained the oil and it was as thin as milk!I'm putting a two barrel back on it ASAP
why is the oil bad? condensation from sitting too long? or is there a coolant leak into the crank case (head gasket)? or was it left out in the open with the engine exposed to the weather do you think?
- Gottolovem
The engine oil was full of fuel washing down the cylinder walls getting into the oil bath.
600cfm drowning the motor fouling plugs etc.
