Access Holes - Front Lower Control Arms
Well, Thanks to member DanT, I have found those hitherto-overlooked access holes for the captive nuts for the long control arm bolts; see the photo.
Since no one prior to DanT had ever mentioned these, I thought the nuts were hermetically sealed in the body at the factory - Wrong!
I would emphatically suggest that anyone removing the control arms remove these covers and shoot the juice to the threads. It would have saved moi a lot of worry when I nearly boogered the threads in one of the bolts.*
While I labeled the smaller plug as for an access hole, it is in actuality too far back for the nut; use the larger hole.
* See https://tercel4wd.com/forums/viewtopic.php? ... 67&p=24929
> Left-click to enlarge
splatterdog
Re: Access Holes - Front Lower Control Arms
Post by splatterdog »
Might not be a bad idea to "juice" that whole compartment now and then. Gotta make sure the bolt has something it can hold on to later..
Lil Beast
My tercel:: 81 tercel sr5 GTS (4age RWD and 4WD application on build up for the moment) now im running a 3a with weber 32 dmsa 100,corolla gts front suspension, sway bar and steering, troush exhaust
Post by Lil Beast »
Looks like a nice rust accumulator to me! Lol Juice it good!
Labine R.
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Post by Mad_Marx »
Rust accumulator indeed! I just finished this operation on Terc II. Control arm bolts on both sides had rusted so much they were one with the inner bushing tube. I ended up cutting them out with a Reciprocating Saw (it took an entire 5 pack of blades to get through the Grade 10 Japanese bolts). It's good to know that I could drive over an active volcano, the tires may burn off and the gas tank may explode, but those control arm bolts ain't meltin' for nothin' !!!
