Also, Whats the Sku # for those?
Autozone employees gave me the blank stare, even after showing them the post. Also, The local Walmart didn't have them anywhere in the automotive section. I Started to search on ebay but seems to be lots of options. Rather buy local.
LED Dome Light Replacement For OE Incandescent Bulbs
Re: LED Dome Light Replacement For OE Incandescent Bulbs
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
85 Toyota MR2 (Blu)
Per the Autozone web site: Part Number: LM50656-60-6
see: http://www.autozone.com/autozone/access ... tid=404819
Features & Benefits
Type S super bright interior replacement lights by Winplus are up to 30X brighter than regular lights. A single 12pk grid of super bright white LED lights can be used to replace or enhance your dome, door, and/trunk lights. See clearly when entering or leaving your vehicle and easily find things in your trunk. -lights come with 4 different adapters to allow for fitments in most cars - simply plug the adapter into your light socket and plug the lights into the adapter. Easy to follow instructions are provided.
Single grid of 12 super bright LEDs
Replaces dome, door, and trunk lights
Up to 30 times brighter than regular interior lights
Connects to 12 V source
Features & Benefits
They seem less than the incandescent. Hmm. I even remounted my 3rd brake light, and even that seems dim.
led light bulbs
led lighting downlights
LED Fluorescent Replacement
led light bulbs
These lights work real well and are cheep.LED lights ebay look up 2x white 16 led car festoon interior light bulbs 31 mm Paid 5.85$ for 6 bulbs with free freight seller is Super360shop this is where i got these. Larry
- My tercel:: 1986 Tercel 4WD Wagon, Manual
I can confirm that these lights do indeed work well in both dome lights. They're significantly brighter AND less of a current draw (and in bulbs likely to be used when the car is off at that) for less than $2 shipped... a no brainer! I might consider trying to find warm white LEDs though, for more of an 80s feel inside.larry mcgrath wrote:These lights work real well and are cheep.LED lights ebay look up 2x white 16 led car festoon interior light bulbs 31 mm Paid 5.85$ for 6 bulbs with free freight seller is Super360shop this is where i got these. Larry
http://smile.amazon.com/dp/B00GXSPL66/r ... TE_3p_dp_1
I wanted something easier than rigging up some wiring and these worked well!
Those look great Paul! Wonder if I can get them locally here.
Paul, I tried opening your link for these bulbs but it doesn't work anymore. Do you know what the part number was that you bought?
- T4WDgambler
- My tercel:: 1985, Toyota, Tercel, manual, 4WD, SR5, stock,
I found these at autozone and they just popped right in and are much brighter. They say they are for off road use only... pff it is a 4wheel drive vehicle!
