Not sure these can be found for the Tercel...but here is how they are done. In my experience much more likely to last than the bolt on or glued together types.
I am using a bolt together boot on my truck...but the CV shaft only rotates when 4x4 is being used...under full time rotation it wouldn't last long. Found that using nylon cable ties in all the "grooves" of the boot helped to hold it together...otherwise the small bolts tended to tear out of the rubber boot.
http://www.saabcentral.com/~munki/techn ... h_type.htm
Guide to installing a stretchable CV boot...
