yes! i totally agree that this is one of the best upgrades. so simple but very useful, at least in rainy climates. i did the same thing on my ae95 shortly after i got it.SynthDesign wrote:I just drove 30 minutes for the 1st time using the intermittent wipers in mixed rain. Wonderful. I think I'm going to have to add this to the must have upgrade list.
Intermittent Wipers..
Re: Intermittent Wipers..
Can the intermittent wiper switch be swapped from tercel to tercel?
Yes they can. They all have the same plugs.
Alright, I have two, one from Dan and one I pulled this weekend out of an 84, that I wanted to swap in to Pokey and Party!
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Anyone have an extra one for a car with Cruise Control? Mine doesn't function in "Int" mode, but works for all the other settings.
- Gottolovem
Not for a cruse control car but if you end up pulling the cruse off i might have one
Does anyone know if the combination switches are the same from 84-89 pickups or can you just use the ones from 4-runners for this mod?
the pickups and 4runners use the same combo switches but you still have to make sure they have the A06 switch. i found it was a toss up as to which kind of switch they had, even though they looked the stalks and hazard light look the same.
So,
As I look a little more, I assume the A10 plugs DO NOT include intermittent wipers. The A06 is needed, more like this?
https://www.ebay.com/itm/254132277601
I'm not sure about A10 plugs but A11 ones have a separate small plug for the adjustable intermittent wiper feature. It was in the photos I posted on the second page of this thread but Photobucket has kindly blurred all my pics because they keep trying to find ways to squeeze a few more $$$ out of people. Anyway, A06 are the ones you want so yes, the ones in that auction are correct.
Hey dlb,
I may go try to pull one of these units off an 87' truck, can you tell me if that steering wheel will take the same size/thread of bolt as the Tercels? I guess I could take some smaller diameter with washers and nuts that I could make work, but it would be nice to have the correct size.
Sorry Chris, it's been a long time so I can't say for sure but I do believe it was the same size nut that holds the steering wheel on the trucks as the tercel. It was big, either 19 or 21 mm I think.
Dlb,
I was asking about the threaded portion of the steering wheel that lets you get a puller on it, usually 0.25”x20 or so, but surely metric for Toyota.
Oh I don't know about that. I never used a puller, just pushed and pulled each side a few times. They take some oomph to do it but not that much.
I think it's 10mm x 1.25
