Well yesterday (1 day before the hurricane Ike hits) my rack and pinion went out in the worst way possible.
I was at a fueling station maneuvering my small trailer and tercel into a tight spot when turning the steering wheel it "slipped". I turned the wheel and it made a clicking sound and the steering wheel turned but nothing else. When I slowly drove and lightly turned the wheel it still turned the wheels. I got the tercel to my work near by where it still is right now. I looked at it and the entire steering shaft going into the rack and pinion is turning but the tie rod ends are not. Have any of you had a manual rack and pinion failure? I'm hoping its not too difficult to replace it.
rack and pinion replacement
Re: rack and pinion replacement
ouch that sux. It is an easy job to replace if you have a whole nother one complete with tie rod ends though...just drop the old out the bottom and slide the new one up...even better if you can find a power one complete
- alex16
- My tercel:: 1983 6speed a/c, towbar, hitch, sr5
i dont want a power rack, I have absolutely no problems what so ever with manual steering, I actually prefer manual. I rather replace this rack with a rebuilt,new, I dont want a used unit. I would not mind taking mine apart and rebuilding it with oem toyota parts.
- Neu
Then go get a haynes or chilton manual and bust into it!
edit: and post lots of pictures and update us!
Might be the splines on the input shaft? Bolt lose or broken?
- alex16
nah as i said in my previous post the entire shaft turns with the wheel perfectly. Everything that you can see turns, just the wheels do not.
I'm not happy because I normally have bad luck with the inner tie rod ends on old toyota's and i also normally having a hard time getting my big american hands into tight places for the rack and pinion mount bolts (with the engine and tranny in place)
