Spoke to tech rep and it is not a listed application,so it cannot be said Monroe will recommend or warranty.End style and length seem correct.Search Monroe shocks to get to catalogues and you can get a dimension chart.Compare specs wth application for Terc for yourself.I accept no responsibility for outcome.
Monroe58510.Advance said they would special order for about $75.Only price I checked.Supposedly 500 lbs total for correct app,which is probably heavier than Tercel.Dunno how that works.kamiphloj
Monroe coil over Spring/shocks for rear
Like my old Volvo 544 with 4wd.I seldom regret neversieze or threadlocker
Monroe coilovers probably won't work
Looking closer at this I suspect there is not clearance for the spring OD to the body at the upper mount kamiphloj
http://www.monroe.com/catalog_lookup/mi ... nChart.pdf
58510 S4 L1/CP3 12.750 21.375 8.625 V/R P577 & P591
MA700 S4 L1/CP3 12.750c 21.375 8.625 None P576 P1134
Here it is compared to the M700...which fits...sort of.
Since it doesn't have the fitting on it you'd have maybe a 1/2" extra clearance or an extra 1" in diameter possible vs the MA700?
right click?
http://www.monroe.com/products/mp_detai ... 0Absorbers
Should fit....somebody got the MA700s to fit with the fitting to the inside by denting the sheet metal in some at top.
I had some 750 lb rated springs (JCWhitney) on some old shocks and they didn't have too much lift.
right click?
