Rear coil spring swap.
ColSwede
My tercel:: 83 Tercel Wagon 4wd
Post by ColSwede » Tue Mar 19, 2019 12:38 pm
So I'm buttoning up the back end after swapping out the coil springs with the pathfinder springs and I'm having a hard time bolting the brake lines back to the frame... Can I leave them off, since they are really only bolted up there to keep them out of the way?
Re: Rear coil spring swap.
Post by Petros » Tue Mar 19, 2019 7:02 pm
as long as they can not move around, they could rub with road vibrations, and bumps, and wear through if allow to move around. they need to be solidly mounted to prevent chaffing on the lines. if you can not get the original mounts back in, try to install some others in a place you can reach that will prevent it from vibrating and moving.
ColSwede
Post by ColSwede » Wed Mar 20, 2019 5:39 am
Thanks. I finally managed to manipulate everything back into place. Holy crap does she sit higher!!
Post by Petros » Fri Mar 22, 2019 4:35 am
share some pictures, want to see that.
ColSwede
Post by ColSwede » Fri Apr 26, 2019 7:57 pm
So here is my baby! Sitting tall and proud! Don't mind the cat, she came with the house. Behind my baby is the donor car I purchased...
