How to lift your Tercel 4wd
discoinferno218
Re: How to lift your Tercel 4wd
Post by discoinferno218 » Thu Mar 22, 2018 7:39 am
FITPerformance wrote:
Thu Mar 22, 2018 7:18 am
If the springs are stiffer they'll compress less than the stock ones when installed, giving you a slight lift. It likely won't be as much as stiffer and taller springs.
Which springs did you get?
All the parts ordered were part numbers from the list in this thread.
asa
My tercel:: 84 SR5
Post by asa » Mon Oct 08, 2018 8:52 am
About to order parts for this for my 84 SR5. Any final warnings? I realize the CV angles but are people actually going through them often? To be honest, I’m doing the lift simply because it’s actually more affordable than replacing the springs with new stock size since it seems the only real option that route is Pedders for new springs.
Thanks,
Asa
SinusoidalTendencies
My tercel:: 87 4wd wagon
Post by SinusoidalTendencies » Sun May 12, 2019 5:23 pm
this thread appears to not have the original topic post and lift write up.
where'd it go?
Post by Petros » Mon May 13, 2019 3:36 pm
search for "Barto lift". it has a fairly long and extensive threat that is still active I think.
Also, search for lift posts by forum member Snythdesign, he has done some extensive work using both the Barto method, and some of his own experiments.
Keep in mind you do not want to lift the front suspension more than about 1" or 1.5" or the angle on the CV joint will be too large and it will wear out very fast. beyond that you have to use taller tires, or go to serioul fame modes to get more clearance.
Post by NWMO » Tue May 14, 2019 7:21 am
S/T,
If you look under the "General stickies library of links" in the General tab, the second heading is "Modifications" and includes one of the definitive discussions on the different lifts used on these cars.
trailerparkzero
My tercel:: 1983/85 halfbreed and a beastly 84
Post by trailerparkzero » Thu May 16, 2019 1:06 am
I did this lift and was talking with the OP about the issues I had while doing it. Maybe he decided to delete it incase somebody killed themselves while attempting it. The strut inserts do not really fit in the strut tubes (too long), part of the post noted that and said to use a big ass channellock to tighten the hell out of the cap. Well I tried that but the best I could get was 1 or 2 engaged threads. I felt it wasn't safe at all and ended up hack sawing 1/8" off the bottom of the insert, as if that was safer. :D Aside from that, the coils are too wide for the lower seat and I'm waiting for the day they unseat themselves. It hasn't happened yet but I only been driving the car for a few days. I've tried my best to make them fail and they're still holding...
I made some mods to the lift by using MR2 strut mounts to lower it 1/2" as I didn't want the full 1.5 to 2" the lift gave. This was also sketchy as the lower profile mounts would contact the spring seats when turning. I ended up bending away the tabs on the mounts. I know this will affect the stiffness of the mounts but I just wanted to see if it'd work. so far no issues. I still think it's too much on the CVs.
I found some old pathfinder springs from a junkyard for the back. Overall my car has a decent rake and looks kinda goofy to me. I love the new stiffness but I hope it breaks in a little. I plan to pull the rear coils and chop and inch or so off to get it closer to level. I also feel that there is not enough downward travel with the pathfinder springs the way they are.
I'm sure there's a better option of parts that will work waiting to be discovered..
I see some people using this lift with huge tires and I cry a little inside as I know they killed the cars low end torque and are destroying their trans, diff, brakes and everything else twice as fast as if they were stock. I'd also bet a stock tercel could handle all the same off roading they are going for. I took my stock 85 up/down serious grades and made it through traills people have claimed required a monster truck to get through. I will say the car is less likely to bottom out with the new set up, I can go over the same stuff as before but faster.
Has anybody cut the rear pathfinder springs? do they just leave them cut or do you need to bend the coil by heating with a torch to flatten the bottom coil?
here's my new 83 with my old 85 guts.
The Professor
Post by The Professor » Thu May 16, 2019 7:57 am
Just cut the coil, don't heat it or the steel will lose its temper. Cutting the spring will make it more stiff than it already is, so be ready for that.
1975 Subaru SuperStar wagon
1984 Subaru Turbo-Traction wagon & Turbo-Traction hardtop
1987 Subaru RX 3-door, x2
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Post by SinusoidalTendencies » Thu May 16, 2019 5:08 pm
trailerparkzero
we're gold tone brothers
