How to lift your Tercel 4wd
BaileySims
Re: How to lift your Tercel 4wd
Post by BaileySims »
Dat flex! Very nice write up too!
WAGON MAFIA.
Blood, sweat and beers.
Hiro
My tercel:: 1986 Toyota Tercel FWD 5spd
Post by Hiro »
How much lift did you get with this? How much of this translates to 2WD models? (I'm assuming very little until we swap front struts from a 4WD)
'86 T2 DLX (114,000 miles and counting)
'90 EE4 RT4WD
'92 EG VX Hatch
'95 YJ 4.0L
'05 C6 Z51 (460rwhp)
teranfirbt
Post by teranfirbt »
Nice, I put Pathfinder springs on the rear of mine and was super happy. What kind of mileage do you get with that setup?
teranfirbt
Considering all of the off road driving I do these days (none :P) I've actually been considering going the other way, give it a nice drop. Something to get the tops of the current tires ~even with the lip of the fenders. Living in Texas the height isn't even an advantage in winter, when we *might* get 1/4" of snow. I'll kick myself the first time I load up the back, but so be it.
Hiro
Post by Hiro »
Are the spring diameters/hats the same for 2wd as 4wd? Is the pathfinder springs just applicable for 4wd models?
'90 EE4 RT4WD
'92 EG VX Hatch
'95 YJ 4.0L
teranfirbt
Abra-Cadaver wrote:
teranfirbt wrote:Considering all of the off road driving I do these days (none :P) I've actually been considering going the other way, give it a nice drop. Something to get the tops of the current tires ~even with the lip of the fenders. Living in Texas the height isn't even an advantage in winter, when we *might* get 1/4" of snow. I'll kick myself the first time I load up the back, but so be it.
guess I could just send you my old springs :lol: :lol: :lol: :lol:
I may just take you up on that! :lol:
Hiro: Front springs should be the same dimensions but different rates for 4wd and 2wd. 4wd springs would probably lift a 2wd a bit. The rear is a completely different suspension type, I've never seen one in person but I don't think they're anywhere near close.
rer233
My tercel:: Multiple
Post by rer233 »
FWD rear suspension is independent mcpherson strut- completely different from 4WD live axle.
jimcrazy
Post by jimcrazy »
my 86 fwd ..4wd struts in the front and 1 1/2 strut spacers in the rear
teranfirbt wrote:Hiro: Front springs should be the same dimensions but different rates for 4wd and 2wd. 4wd springs would probably lift a 2wd a bit. The rear is a completely different suspension type, I've never seen one in person but I don't think they're anywhere near close.
I have found this was not true with a set FWD front struts I took off an '85 Tercel FWD wagon parts car. the FWD struts are an inch (25mm) sorter, but everything else should be identical. I took the FWD struts apart to use the parts, and out of curiosity measured it, their coil dia, number of coils, and length was the same, but the wire dia was thicker off the fwd as compared to coil springs off an '87 T4wd. So the FWD springs were slightly stiffer than the 4wd front springs.
Might be due to year difference, or someone replaced them with aftermarket springs, but I was surprised to learn that the FWD was different. I installed the stiffer springs in the '87 T4wd. Both btw were originally equipped with A/C.
with a car this old and messed with by various previous owners and mechanics, anything is possible.
teranfirbt
Interesting...
Hiro
Post by Hiro »
YES YES YES!!!!!
Abra, that is AWESOME!!!! Good work! Did you offset the transmission mount to account for the front lift? Has anyone considered doing the same with the tie rods or ball joints?
Not to completely derail, but does anyone have a second set of front, worn out, 4WD struts they won't miss if I pay shipping? Would love to compare to my factory original '86 suspension...
Petros, when you say the '85 fwd strut was 25mm shorter than the '87 4wd strut, was that just the strut housings by itself without the shock insert you were comparing?
'90 EE4 RT4WD
'92 EG VX Hatch
'95 YJ 4.0L
BaileySims
I should have mine, or at least I think I do. I'm not sure of the condition but I'll check as soon as I get off work today.
WAGON MAFIA.
BaileySims
Looks proper! They should have came from the factory with that lift and tire size.
WAGON MAFIA.
jimcrazy
Post by jimcrazy »
for some reason my 85 sits up nice in the front compared to my other wagons,,all stock front end on 185-70-14 tires
Hiro,
the factory strut has built in shock tube, piston and valve, not sure if it is different, it might have a slightly different travel length. The insert you buy is the same for FWD or 4wd, so for what it is worth, your travel length would be the same when you install an insert.
you need to watch the amount of front lift you get with taller springs or struts, it puts a sharper angle on the front cv joint, which means more movement in the joint every time it rotates. It causes the cv joint to wear out faster. ideally you want zero angle on the cv angle when it is neutral loading, minimal angle. using larger dia wheels and tires helps give more ground clearance without the larger angle (though you have to verify you do not rub in the wheel wells on rebound). The only way to reduce this CV angle with lift is to lower the transmission (and the engine comes with it). but than you loose the center clearance that you wanted to get by rasing the body.
So check your CV angle, likely you would be okay with about 1.5" of lift, but another form member (Synth) found he wiped out a new set of CV axles in only a few thoursand miles. He also damaged the upper seal on the strut because they were topping out on the rebound, so you also want the strut to be approx at the cente of its travel when it is at rest.
