Vacuum Advance Issue
Jonymoto
Re: Vacuum Advance Issue
Post by Jonymoto » Sun Feb 14, 2016 8:42 pm
Mark, what I meant was - if I wanted to I could install a tee in the line from the gas filter and K. From memory both ports on the gas filter already have tubes connected to them, one presumably to K.
Jonymoto
Post by Jonymoto » Mon Feb 15, 2016 1:22 am
I connected the dizzy to the manifold and carbie as you both suggested and the timing does change by about 8 deg when the engine is idling. I took it for a drive. It definitely has better acceleration, is smoother and feels more like it did when it was new. Thank you very much for your help.
I do have another question. My Tercel is equipped with some sort of temp activated valve on top of the rocker cover which I haven't seen on any other Tercel or 4ac engine. My previous 3ac dizzy with single port vacuum advance was connected to one outlet of this valve. Another outlet was connected to the port on the carbie nearest the idle speed screw. I wish I could show you a photo of it but I don't know how to load photos yet. I think it was meant to prevent vacuum to the carbie until the engine had warmed up. Would it be a good idea to connect the carbie to the dizzy via this valve again?
Post by dlb » Mon Feb 15, 2016 8:27 am
sorry jonymoto, i have no idea what sort of temp-activated valve on top the the valve cover you're talking about. on tercels over here, there is no similar device -- the dizzy gets vacuum advance at all temps. so i think it's probably fine both to leave it as it is right now, or to reconnect the lower vac advance port to that temp switch.
Jonymoto
Post by Jonymoto » Tue Feb 16, 2016 12:26 am
Thanks dlb. I will leave it as it is, i.e. bypassing the temp switch. Thank you very much for all your help.
Post by dlb » Tue Feb 16, 2016 6:42 am
no worries, glad to help.
GLet71
Post by GLet71 » Sat Apr 22, 2017 10:15 pm
Hey Jonymoto,
Any chance that Aussie Tercel of yours is sporting over the shoulder seat belts for the back seat? I would love to see some photos if you do, because I am currently trying to install some in my '87. I've started the project on one of my parts cars, and I can't help notice that all the holes are there for me make it work. The problem is having the correct seat belt hardware, so any pics would be of service.
Sorry for highjacking the thread.
Post by dlb » Mon Apr 24, 2017 7:00 pm
greg, i posted one photo of the stock rear shoulder seat belts. it's the 5th pic down in this post
viewtopic.php?f=6&t=9426&hilit=project#p68414
it was a weird system because they were really just sort of an addition to the regular lap belt. IIRC, the lower end of the shoulder belt had a plate that locked into the female end of the lap belt. you can see the locking plate in the pic i linked to. i wish i could tell you more beyond that but i never paid much attention to them, and i sold that car long ago.
GLet71
Post by GLet71 » Mon Apr 24, 2017 8:09 pm
I was having a flashback thought like this one you've shown here. I remember having an old Dodge Dart that had a similar 'lock on' shoulder strap like this, and wondered whether I could retrofit something onto Ron.
Post by Petros » Thu Apr 27, 2017 8:08 pm
unless you want to have "original" toyota parts, it would not be that difficult to adapt aftermarket seat belts with shoulder belts for the rear. find something out of a wrecking yard about the right color and fabricate a bracket to make it make it work.
