Carburetor disassemble and assemble video
Shanemt
My tercel:: 1983 sr5 4wd wagon
Re: Carburetor disassemble and assemble video
Post by Shanemt » Thu Aug 22, 2019 5:42 pm
The Professor wrote:
Tue Aug 20, 2019 9:17 am
Shanemt wrote:
Fri Aug 16, 2019 5:20 pm
Can anyone tell me where I can get one of these filters and the rubber tubes that connect it?
Someone already answered your question in the other thread, but it's a one-way check valve. Can be replaced by a universal part.
Thanks for the info! What about this spring that came from the back of the carb that closes the butterfly valve to the proper idle position after you let off the gas? It’s wrapped around the metal piece
Ismo
My tercel:: 87 wagon
Post by Ismo » Sun Mar 08, 2020 5:06 pm
Is the float level chart the same for 83 and 87?
Post by Petros » Mon Mar 09, 2020 5:48 pm
yes, it should be. there were a few minor changes to the emissions system, and the jetting, but the carbs are almost identical and the floats are all the same.
Ismo
Post by Ismo » Sun Mar 15, 2020 7:05 pm
Thanks petros it worked pretty good, car is happy.
Erikwi
My tercel:: 1988 stock auto
Post by Erikwi » Sat Sep 05, 2020 1:20 pm
https://youtu.be/9UFgCyHWDns
the primary on mine looks strange
can anyone confirm that the fuel should dribble out not atomize?
