Could you give me a link. What I found at rockauto was the water pump without the housing. Its the housing thats cracked.larry mcgrath wrote:Rockauto sells water pumps cheep, a pick and pull pump is a gamble at best, with a new pump you get new bearings and shaft seal------the seal is what generly starts leaking First--. Un-less you like dooing this over I'de go with a new pump. Just my experence. Larry
I get it now. Use the pic-n-pull housing and get a new pump. Well I already put it in so if it dont work all replace it.
