Rear Differential Pinion Seal Replacement Video
https://www.youtube.com/watch?v=WAhzyGDK3Z0
also made this one which i believe is better
https://youtu.be/z_eGBPxU5Jk
DISCLAIMER
This method works for me because I do not use 4WD unless it snows and that does not happens very often where I live. I have done this several times over the last 14 years without any future problems, BUT If you use 4WD quite often I would not recommend replacing the seal unless you reset the differential to Factory tolerances per FSM (factory service manual), see the section on setting the gear lash etc.
Re: Rear Differential Pinion Seal Replacement Video
the pinion shaft has two angular bearings (forward and aft) that require a small amount of tightness and zero play when pinion nut is tightend to the correct pre-load. Pre-load is the amount of torque (inch/pounds) it takes to rotate all of the gears in the differential (removed from car or left in car with axles removed).
there is a sleeve (spacer) between the two bearings that collapses when compressed (by tightening the nut). if it squished too much the bearing will be too tight (pre-load over 9.6 in/lbs) and could cause the bearings to overheat and fail. If pre-load is over 9.6 in/lbs the sleeve has to be replaced.
in my second video i am trying to get things back to the way they were without replacing the sleeve or bearing.
Thank you for making these Videos Xirdneh
