Unfortunatly I could not Upload Higher Quality videos because it takes too long (24 hours and only halfway done so i quit)
I converted to mpeg1 and tried mpeg2 files and that went way faster but quality suffers
I need to know what kind of file I should be converting these to for best quality vs upload speed
anyone have any ideas?
http://www.youtube.com/watch?v=FtM4IqmoXUU
Tercel 4WD Manual Transmission (part 1) Output Shaft
Taking the 1983-1988 Toyota Tercel Manual Transmission Output Shaft apart and putting it back together. Gears, Bearings, Synchros, Snap Rings, Shift Keys, Sliders
http://www.youtube.com/watch?v=Ta4KTrcfgtg (part 2) Countershaft
https://www.youtube.com/watch?v=vhFGYj_xTuA (part 3) Input Shaft
http://www.youtube.com/watch?v=mjYj6h0kBv4 (part 4) Idler Shaft
https://www.youtube.com/watch?v=-YZz2iIEmy4 (part 5) Intermediate Plate Assy
http://www.youtube.com/watch?v=Vj1H78QZgJA (part 6) Main Case Assy
http://www.youtube.com/watch?v=BVeTzW3merk (part 7) Extension Housing
http://www.youtube.com/watch?v=6OvzgtbKvfo (part 5th gear instal and final assy steps
http://www.youtube.com/watch?v=YG68HLkyMq8 (part 9) 1. Shift Fork Information (good vs bad), Steel and Aluminum Forks. 2. Shift Fork Repair by Brazing. 3. Gasket Making. 4. Restrict Pin Inspection and Repair. 5. Bracket for installing tranny and how to use and build it.
https://www.youtube.com/watch?v=l7TwqUEFZtk (part 10) transaxle Remove and Install Bearing (KOYO 20BTM2920 or DB501901) for end of tranny counter shaft. Install Seals
Transmission Repair Youtube videos
Re: Added transmission Youtube video on Output Shaft Gears
WOW!
