Like many, I tired of having to beat hard on the center of the steering wheel to operate the horn.
So when I had it off to install the wiper/signal cluster, I had an idea: Perhaps the vinyl cover just needed to travel a little less to contact the movable actual switch?
Yup.
So I just superglued a 5 mm ring I had left over from the bike shop. It works!
Of course, one look at the photo and you will note that a substitute can be readily used. Heck, even a ring cut from an appropriately-sized PVC pipe would work.
Left-click to enlarge.
Fix for Horn Push
Fix for Horn Push
- garyfish
Re: Fix for Horn Push
couple other threads on horn repair:
https://tercel4wd.com/forums/viewtopic.php?f=7&t=8340
https://tercel4wd.com/forums/viewtopic.php?f=7&t=9490
- Mattel
Yes, I've used the method Keith posted in that first link but I used a circular piece of yoghurt container that i cut instead of gasket material. worked a treat.
