My SR5 Tercel
2mellow4wd
Post by 2mellow4wd »
This is my ride, I just put the wheels on, and i am still working on making the interior looking like new...
... the interior is the blue burburry, I made a new shift boot to match, very nice, I am still trying to figure out how to mount a new small shift boot for the 4WD shifter, and also the measurments for the E-brake handle... any ideas on the 4WD shifter would be great...
Tell me what you think about my ride,
Joel
MootsMan
Post by MootsMan »
Good looking wagon, Joel ! Looks to be rust free in the pics. I took a shifter boot out of a Mazda MX3 at the junkyard and put it in mine, on the transmission shifter. Haven't tried anything on the 4WD shifter yet. My wagon is dirt colored.....like the white a lot, though ! Are those 13's or 14's ??
2mellow4wd
Thanks, the funny thing about the paint though is it originally was silver instead of white, and the blue was blue, but who ever painted it painted over the pinstripes instead of peeling them. other then that and the fact the blue needs redone the outside is great...
Yeah I have exp. sewing so it was just easier to take the measurments and sew it up rather then try and find one i good condition, considering my salvage yard options are very limited, i have like 3 to choose from, and one doesn't even have a Tercel in the lot, and the one that does charges ridiculous amounts and they still want you to pull the part yourself. In Kansas CIty, there is a place called U-wrench it, you have to bring your tools and pull the parts you need, with that though everything is dirt cheap, like they have specials where you fill up your wheelbarrow with as much as you can and its a set price... awesome place.
the wheels are actually 15" with 205/5015's, i had them on my escort but i am turning that into a road course racer...
Thanks,
Joel
grzydj
Post by grzydj »
Looks good with 15's. Is the back loaded down or something? It looks like it's sagging a bit.
GTSSportCoupe
Post by GTSSportCoupe »
Nice tercel! Thanks for the pics.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
2mellow4wd
No actually if you look at the paint, the front wheel well arch is higher then the rear... so it makes it look lower... my boss asked the same thing...
Joel
icE
Post by icE »
mm post deleted user banned :)
what a loser :P
sweet tercel though! the wheels add a nice touch ^_^
3A-C Power
Post by 3A-C Power »
Nice car.
I assume you've taken off the plastic trim that the shifter boots are mounted to? The shifter boot is stapled to these plastic pieces which are screwed to the big piece, and they just have to be stapled to the new leather when you make the boot. Is the 4WD shifter any different?
2mellow4wd
Actually my shift boot is held in place with a metal ring. no screws, or staples, so it was extremly easy to install, as for the 4wd shifter, it is quite different, the shifter was mounted on these plastic posts, then a metal ring installed then the melted down the post so the aren't screwed on or stapled, so for that i am sorta SOL untill i can figure some thing out. actually i don't think it even has a metal ring. now that i think about it i can't remember what holds it in other then the melted tabs...
Joel
I'm thinking of replacing my shift boots with neoprene (wetsuit material). I've noticed a lot of modern cars (Nissan X-trail) etc have this finish on the interior. as it's a flexible elasticated material. I should be able to get quiet a tight fit
Matt
Inkyturbo
Post by Inkyturbo »
Does anyone have any other shift boot replacement options? Do any of the leather shift boots from AutoZone and NAPA work?
Josh G.
Joy is passing a brand new car at 80 in the fastlane, with your 22 year old Japanese economy car.
1983 Toyota Tercel Wagon (4WD, SR5)
