83 sr5 maxima vq30de & 350z 6 speed swap
nissan-tercel
My tercel:: 83 4wd sr5
Post by nissan-tercel » Fri Sep 28, 2018 9:40 pm
Brief introduction. Names Joey. Hi. New to the forum. Looks like an awesome community. Maybe a little cultish Hahah jk always loved the tercel wagons and moving from Florida to spokane Washington in about a month. Wife is in the air force. 26 year old stay at home dad of 2 little boys. Joseph (3) and Dexter (2). I am a christian and owe everything to my loving creator.
I've built several z cars from high comp triple Weber 40s to turbo 300zxs to 350zs. Usually more of a nissan/datsun enthusiast but a new chapter in my life has left me wanting to do a crazy swap. But im a huge fan of most 80s japanese cars. The uglier and more 80s the better. Aka tercel. Just love these cars.
So Lord willing gonna be picking up a red 83 sr5 in a few weeks. No motor. Will be selling the manual 4wd trans.
Swap plans:
CHASSIS:
-83 tercel 4wd sr5 wagon
BUDGET: $3,000
ANY VQ30DE/DEK ENGINE
FROM 95-96 MAXIMA:
-Alternator and wiring
-Engine harness and all appropriate sensors
-dash harness and gauges
-ecu
-maf sensor
-fuel level sender
FROM Z/G:
-complete transmission assembly
-slip yoke
-rear coolant pipe
-starter
-headers
INTAKE MANIFOLD:
-flip a32 intake forward.
OR
-Make custom forward or side facing from a32 manifold
(May cause hood clearance issues)
OR
-00vi maxima intake cut and flip
(Enlarge holes in upper)
OR
-vq35 pathfinder upper
(Drill and tap lower, or flip lower and enlarge holes in upper)
-Adapt a32 iacv
DRIVESHAFT:
-weld z/g yoke to chassis driveshaft and have balanced.
The BIG UNKNOWNS!😬😲
-General clearance issues
-May need z oil pan setup
-Exhaust fitment?
-Intake manifold could be a headache.
-Custom shifter
-hydraulic clutch assembly
(Pedal, master, slave)
CUSTOM:
-mount brackets
-shifter?
-throw out bearing spacer
-driveshaft
-intake manifold
-cut oil pan for starter clearance
-correct starter spacing
Loose budget:
Chassis: 500
Metal: 60
Engine, harness, ecu, maf: 230
Transmission: 400
Starter: 30
350z rear coolant pipe: 50
Intake manifold: 21
Intake: 20
Driveshaft: 100
Radiator: 15
Oil and filter: 27
Gear oil: 40
Coolant: 12
Hoses: 30
Hardware: 25
Mounts: 55
Battery and cables: 80
Relays,wire, switches butt connectors: 30
Exhaust shop: 150
Clutch kit and flywheel: 100
Slave and clutch lines: 75
Inevitable miscellaneous stuff: 400
350z headers: 67
WIRING:
95-96 a32 maxima ecu & harness
12 volts switched: 24 (red)
Start signal: 20 (brown/white stripe)
Grounds: (black)
10 19 25 32 108 112 116 124
Sorry for the long post but i plan to have this as a build thread.
Thanks again. Hope this is a friendly loving family hahaha. God bless.
Last edited by nissan-tercel on Sat Sep 29, 2018 10:01 am, edited 1 time in total.
LowBuckCanuck
Re: 83 sr5 maxima vq30de & 350z 6 speed swap
Post by LowBuckCanuck » Fri Sep 28, 2018 9:50 pm
This will be fun to follow. One problem I noted: I assume your creation will be rear wheel drive. I reckon you will need the rear end out of a corolla gts (ae86) for that to work.
The tercel's rear end doesn't have a true differential, i.e. when power is sent to it both wheels spin at the same speed. No slip when going around corners.
Now this sounds great for drifts and whatnot, but the tercel rear end will most likely be destroyed after a short period of time.
The stock ae86 rear end bolts right in (I think) and is a bit beefier with a stock limited slip differential. The hub size is different however.
Hope this helps and I look forward to seeing pictures!
nissan-tercel
Post by nissan-tercel » Fri Sep 28, 2018 9:53 pm
Thanks for the comment. Honestly i did not know that about the diff. So i assume it still has a ring and pinion correct? Or is it some crazy unlike anything design?
nissan-tercel
Post by nissan-tercel » Fri Sep 28, 2018 9:54 pm
However if im being honest im making the driveline myself and ill probably use the rear end till it dies
nissan-tercel
Post by nissan-tercel » Fri Sep 28, 2018 10:10 pm
I mean theres basically two ways it could spin both wheels equally it seems:
LSD (which is not the case)
Or
There are no spiders and the axles just slide into the pumpkin..... Thatd be very strange. But we'll see how it holds up.
It is going to be a daily driver and really not wanting to run through tires so I may just save myself the time and throw a hilux rear end in it or something.
I know the Toyota rear ends are a 7.5 inch but theyre 56 inches wide. The narrowest rear end i can think of that is readily available at junk yards would be an s10/sonoma rwar end at 54 inches in width. With a 7.5 or 7.65 ring and countless ratios that would be a better bet.
But that really just depends on the width of the factory tercel rear end from mounting surface to mounting surface.
Can anybody get me that measurement by chance?
nissan-tercel
Post by nissan-tercel » Sat Sep 29, 2018 6:48 am
So I've found that the factory rear end is a hypoid type. Im assuming this design was used to eliminate the need of a driveshaft tunnel in the car?
rer233
My tercel:: Multiple
Post by rer233 » Sat Sep 29, 2018 7:25 am
Our cars have no CENTER diff (which you'll do away with when you convert to RWD.) Rear diff is standard "open" type. Doubt it will hold up long behind the HP you're considering 'tho.
nissan-tercel
Post by nissan-tercel » Sat Sep 29, 2018 7:31 am
Yeah thats what ive found. Im just wondering if I'll have to cut a whole tunnel for the driveshaft when swapping swapping to a regular differential......
rer233
Post by rer233 » Sat Sep 29, 2018 7:35 am
Driveshaft tunnel's already there- two-piece driveshaft.
nissan-tercel
Post by nissan-tercel » Sat Sep 29, 2018 7:41 am
Sweet. I know ill be hacking for the trans tunnel. Hoping it wont obstruct the factory interior too badly once its put back together. Id like to retain heat and AC.
nissan-tercel
Post by nissan-tercel » Sat Sep 29, 2018 9:41 pm
Looks like ill probably be going with a rear end from a 2wd toyota pickup.
Post by Petros » Sun Sep 30, 2018 12:21 am
welcome to the forum!
sounds like a crazy project. that original T4wd trans is likely worth as much as the rest of the car, so make sure it goes to someone that needs it and will appreciate it.
If you are getting a z car as a parts car why not just put the IRS from the back of the z car into the Tercel? it will be strong enough and you know it will handle the power. Otherwise that light funky little econo-box Tercel may not handle the drastic power increase very well. Yes it will be a lot of work, lots of sheet metal cutting and welding, but you will be needed to do that anyway.
BTW, I am very familar with that z car engine and drive train. I worked for the Nissan contractor that developed the race cars that the factory backed in the late 70's and early 80's. I assisted in developing the 280z, and the 300zx race cars, I designed the head that went on the GTP 3 liter turbo that was undefeated back when Nissan was sponsoring the racing program. I also assisted with the suspension development, and designed the throttle linkage and part of the induction system that went into the race car. The engine developed about 1000 hp, not bad for a 3-L production based engine in 1985. I got out of the buiness after I moved to Washington state, and just tinker with old cars like the T4wd now.
nissan-tercel
Post by nissan-tercel » Sun Sep 30, 2018 3:04 am
Awesome! I've built plenty of the vg30et from tge 84-89 300zx like what was in the gtp-zx turbo! That's pretty wild! I look forward to the project!
SynthDesign
Post by SynthDesign » Thu Oct 04, 2018 10:34 am
The stock open rear end is good for a limited amount of torque. After about 200ftlbs, the open diff eats a pinion. It's a fun chasis for a RWD setup. Your going to want to use AW11 MR2 85-89 front hubs/knucles to deal with the removal of the front CVs. Stubbin the stock hubs doesn't work well.
Lookin forward to some pics.
85 Toyota MR2 (Blu)
86 Toyota Tercel 4WD DLX for sale (BluBoy)
86 Toyota Tercel SR5 Canadian Import (Galena)
83 Mazda RX-7 Mariah Widebody
Wait I have more
nissan-tercel
Post by nissan-tercel » Sun Oct 07, 2018 8:40 pm
I have two questions because i assume you've done a rwd tercel.
1- what do you mean by doesnt work "well"?
2- is there any other changes or modifications to use the mr2 knuckles?
