new member ..85 sr5
Re: new member ..85 sr5
you will have to make your own front bumper, that one in the pic was something offered as a dealer installed option in Germany only, likely locally made and supplied. doubt there are any survivors this late in the game. They likely did not sell many either.
I would be happy with a set of Euro or Japaneses bumpers, nice and slim profile and lighter. we get stuck with the idiotic federal bumpers, which have proven to be a big mistake (minor repairs are more costly than with standard bumpers, and those big bumpers cause severe injuries to pedestrians in accidents).
mr_braaaap
My tercel:: 1985 bone stock
Post by mr_braaaap »
Today’s progress .tmm I will try to bolt the trans mount and start it .it was getting late already
mr_braaaap
Well today I finished installing everything.i still got the ac compressor off I want to install new orings.i got to put the axles back .and speed sensor .it took a long time connecting everything back . I take my time too . There is a blue plug that has nipples for vacuum lines . They broke off . I just connected them together so they won’t be no vacuum leaks .i need to know how much gear oil does the transmission take because a lot of drained out when I removed the engine . Here is the only pics I took today
the trans holds 4.1 quarts of gear oil. makes sure it is fully topped up or severe damage to the trans will result. I use the front fill plug on the side of the diff housing near the CV axle. make sure it is level, and you get it it completely full.
mr_braaaap
Petros.thank you again for saving me lol im going just to. Drain the whole transmission out first and then top it off . Thanks btw
mr_braaaap
Well today I installed the cv axles I pour 4 liters into the transmission and also connected the shifter assembly and I tried to start it but it didn’t .it just kept huffing and puffing our the carb . I didn’t know that the distributor had to go a certain way . So I was already tired and it was raining so tmm I’ll make sure I doit right and make sure all the vacuum hoses are right well here is the pic of the day
mr_braaaap
yea it did ..i barely drive it ...is really fun to drive specially making sharp turns lol
