FRQ wrote: Sat Dec 30, 2017 8:53 am
I've been lurking here for about a month or so when the inexplicable bug to get an obscure 4WD bit me. Not my first rodeo, I have a bit of a Land Cruiser 60 series "problem".
After some searching, I managed to turn up this 2 owner 152000 miles '84 in France. No power steering or AC, does have an electric sunroof. I haven't had it up on a lift yet, but have seen pictures and the underside looks to be solid, fingers crossed a more profound inspection doesn't turn up any nasty surprises. First off, some pictures:
Bonus picture with one of her big sisters:
Cosmetically, at the moment the biggest letdown is the rear hatch, peeling clearcoat and some rust bubbles along the window edge. At least 1 of those 2 issues should be easily remedied. I'm also on the lookout for a set of MR2 3 spoke wheels.
In terms of rust, there are some small bubbles on the left rear wheelarch and on the inside bottom of all doors. Nothing major yet, but worth sanding down, treating with rust converter followed by some paint.
Of course I have questions, lots of them:
-Front axle shafts are shot (loud ticking noise when turning under load), the Toyota EPC number didn't turn up much here in Europe, which is a bit unusual in my experience, are these worth getting? Not familiar with US brands:
https://www.ebay.com/itm/Toyota-Tercel- ... 2115555357. Should I go ahead and replace the seals in the axle housing as well? Any other bits that might need doing while I'm tearing into the front suspension? Anti-roll bar bushes from what I've seen here? Bearings perhaps?
- Heater: cold/hot slider is properly stuck, anything mechanical that can go wrong with these other than the heater valve in the engine bay and the bowden cable that might need lubing?
- Difficult cold start: I take it the automatic choke isn't working properly? Should I just throw a rebuild kit at the carb and replace all vacuum hoses while I'm in there and call it good or shouldn't I bother and just get a Weber?
- Tires: any EU available brands that are still making a good 14" A/T? The only thing I found was a General with a 165 width for the Fiat Panda 4x4. I'm considering a set of rally gravel tires (Fedima, DMACK), but those are pricy...
In terms of general maintenance, I plan on replacing the timing belt (non-interference engine if I'm not mistaken?), adjust valves and change all fluids. Any recommendations for engine oil (mineral? weight?) and gearbox/diff oil?
I'm sure I have about 50 more questions, but none come to mind at the moment. I'm also looking for some parts for a brown interior:
- ashtray
- shifter boot and knob
- knob for heater control slider
- set of good condition OEM mudflaps
- possibly some door handles and a few other small bits of trim that haven't developed a whitish sheen from UV exposure.
Anyway, it's something different from my diesel 60s, that's for sure, but at first glance this should be a fun little daily driver, excited to get it registered and spend way too much time pouring through the threads on this forum.
