RWD Battle Wagon
SirFoxx
My tercel:: 1988 DLX Tercel Wagon w/ weber (RIP), 1985 4wd Tercel SR5
Re: RWD Battle Wagon
Post by SirFoxx » Sun Feb 25, 2018 1:22 am
I have another question. How did the exhaust manifold fit previously on the 4age? I am still in the process of gathering parts, and saw this manifold for sale, and wondered if it'd clear the steering shaft.
(https://www.protuninglab.com/hds-tc85-a ... 0848870138)
Post by Petros » Mon Feb 26, 2018 2:31 pm
that is a great price. no it will not fit, the AE86 body is shapped different and the engine sits much lower. but it would be a good place to start and might be worth buying.
you have to the weave the lower pipes around the steering shaft, the starter motor and the outlet has to be lower than on the AE86 (the Tercel engine sits higher because of the front diff on the 4wd/FWD trans). But you would have to build something up from scratch to do the same thing, buying this might save you about half the cost of making a completely new header. You would cut it off about half way down, and than use the parts from the lower end to build in place a new lower end. A complete custom header done in a regular retail shop would cost in the $700-1000. You can make one up yourself, but that is a lot of work and custom parts to make from scratch, so starging with one like that might be worth it because it likely costs less than the material costs alone.
I bought a similar one, but different brand, with the plans to alter it to make it fit. This one looks like a better design than the one I bought for about the same price several years ago.
I would also count on making a heat shield for both the steering shaft, and the starter, and perhaps the steering rack. Also, wrapping the header with a heat blanket should also protect these parts.
SynthDesign
Post by SynthDesign » Tue Mar 06, 2018 4:30 pm
4AC Bottom end? As in wrong connecting rods?
85 Toyota MR2 (Blu)
86 Toyota Tercel 4WD DLX for sale (BluBoy)
86 Toyota Tercel SR5 Canadian Import (Galena)
83 Mazda RX-7 Mariah Widebody
Wait I have more
terceldude
Post by terceldude » Sun Mar 25, 2018 11:52 am
Sidedraft EFI or Sidedraft Carbies?
K-Business
white_raven
My tercel:: 1987 toyota tercel 4wd
Post by white_raven » Tue Mar 27, 2018 11:18 am
Hey guys it has been a while, still in progress of building the motor.
Petros was right, the geometry on the mr2 spindles in stock form are horrible for the tercel, nothing lines up correctly. I suspected it could be modified but it looks like much more than I wanted to do, so my next plan is to swap the mr2 hubs into the tercel spindles.
Manual rack is installed but I will need a new intermediate shaft as the stock tercel one is not long enough to reach new rack.
To answer SirFoxx's question: The exhaust manifold that was in the tercel was pretty hacked up and also had an inch or so spacer on it. I think you'd have to have a custom manifold made or mod an off the shelf one quite a bit.
The 4ac bottom end had some issues, wrong pistons, wrong water pump, tons of hacked crap on it, and worst of all some pretty bad piston slop. I didnt want to deal with it.
The 7age I am building will be fuel injected.
only progress pictures i have take so far.
4age head off and getting ready to be taken in for head work.
Its so dirty =(
tons of carbon build up on the valves. GROSS!
7a block cylinders look pretty good.
pistons are dirty but those will be replaced anyways.
white_raven
Post by white_raven » Thu May 31, 2018 11:36 am
Like normal having made tons of progress lately. Family, Church, and Work keep me pretty busy, but was get to get the head and block off to machine shops to get some work done.
I took the head to a local toyota guy Dan OST, pro at 4ag heads.
Turns out the head needed a ton of work, it was warped and needed resurface, it had 2 bent valves, on the flip side we found it someone had did some port work on the intake side, it got new valve seals and it had bigport cams! Should be interesting to see the torque curve from the big port cams on a small port head.
Anyways on to pics of the refreshed head!
Now we wait for the 7a block to get cleaned up at the machine shop, then the fun part comes with reassembly.
white_raven
Post by white_raven » Fri Jun 15, 2018 11:19 am
more engine progress finally!
Got the 7a block back from the machine shop all nice and cleaned up! Cylinders hone, block decked crank polished and everything spec'ed out.
Ended up going with stock 7a rods and bigport 4a pistons using press fit wrist pins, shooting for a 10.5-10.7:1 compression. Block was decked so the pistons had zero deck height. Got bearings on order from toyota and once they are in I can then start the reassembly process. so for now on to a few pics!
On the block I found what looked like weird casting flaws, I tried to remove the excess material but it does not want to come off.
and of course I found it where I would least want it.
7a rods + 4a BP pistons assembled with press fit wrist pins.
And this is what happens when you let your kids pic paint colors at the store. Haha
jimcrazy
Post by jimcrazy » Fri Jun 15, 2018 12:43 pm
if you are using the 3a oil pan should have had the shop address the cut out on the left side of the block so the pan will seal
jimcrazy
Post by jimcrazy » Fri Jun 15, 2018 12:45 pm
my bad didnt see the rear drive part
white_raven
Post by white_raven » Fri Jun 15, 2018 3:22 pm
yea the oil pan part is going to be tricky anyways because of the crossmember and the transmission doesnt line up correctly either. so Im not totally sure what Im going to do on it yet.
nissan-tercel
My tercel:: 83 4wd sr5
Post by nissan-tercel » Sat Sep 29, 2018 12:37 pm
Sweet! Any more progress here bud?
RussiAL25
My tercel:: Sprinter Carib AL25 1987
Post by RussiAL25 » Tue Jan 29, 2019 7:55 am
Hello! I am new to this forum, I’m interested in the question, has this project been completed, has everything worked out?
AugustusFerdinand
My tercel:: 1983 Toyota Tercel SR5
Post by AugustusFerdinand » Tue Aug 20, 2019 3:15 pm
Any progress?
Also I assume you meant you're using 4AG smallport pistons on the 7A rods as everything I've seen says the bigport pistons are 18mm wrist pins while the 7A and smallport use 20mm wrist pins.
The Professor
Post by The Professor » Wed Aug 21, 2019 7:50 am
Any progress?
The OP hasn't logged in since the end of January 2019. We may never see this project finished...
1984 Subaru Turbo-Traction wagon
1984 Subaru Turbo-Traction hardtop
1987.5 Subaru RX 3-door
