3ac-scv
4wd front sturts
cut pathfinder rear springs
kyb shocks
weber 32/36
Battle Wagon II (rwd):
4age/4ac hybrid
st 20v itbs
sq engineering adapter
manual rack
t50
Recently I acquired the a tercel with a fwd 4age swap done by a former member. At the time I got the car I was under the impression a rwd conversion would be pretty easy until I did some research. This lead my friend and I to look for a project to convert to rwd. We found the prefect candidate in a 87 4wd 0tercel in Mcminnville with a jdm 3ac swap but the owner had also swapped in a 83 trans/transfer case while leaving the 87 rear end on causing the trans to grenade. The plan would be to pull the 3ac from the 4wd tercel and put it in the fwd tercel and then convert the 4wd tercel to rwd with the 4age.
So with that introduction here is the Current Project Fleet:
Left to Right: Green 86 4age Tercel (Turdcel - 4age swapped) - AllTrac Camry (Eventually will be swapped) - White 87 4wd Tercel
4wd Tercel is pretty clean
JDM POWA! 3ac-SCV apparently has different intake than a standard 3ac which gives it more power? Im not quite sure the difference.
