555555.5 km
555555.5 km
my old 86 fwd rolled over 555555.5 kms not miles on way home tonite, still running strong
Re: 555555.5 km
= 345206.18339 miles.
Impressive!
Impressive!
Re: 555555.5 km
are those the true kms for the FWD? did you swap the odometer over when you swapped clusters?
Re: 555555.5 km
when I swaped the cluster they were within a couple thousand kms
- Jonymoto
Re: 555555.5 km
I didn't realise you guys in Canada use Kms. Do you use litres as well or US/imperial gallon? Jim, have you done a compression test on the engine cylinders lately. Just wondering what sort of figures you get on an engine that's done that many kms, especially in your cold climate.
Re: 555555.5 km
yep, liters and km. we're all metric, although lots of people still use lbs and feet/inches casually when talking about height and weight, or you're buying meat at the market, that sort of thing.
- Jonymoto
Re: 555555.5 km
You learn a lot on this site and not just about the Tercel, for examle, I like it when you guys put your locations in your profile. I get to check it out and learn more about places I've never heard of.
