the 4a allmost ready to drop in
jimcrazy
Post by jimcrazy »
been gathering bits and pieces all winter and slowly putting it together.spark plugs, air filter,cam seal,crank seal,oil pump seal,valve seals,valve cover gasket,u-joints for the drive shaft,clutch kit, upper and lower rad hoses, thermostat and water pump and timing belt. hope it works good when done. also got a 5200 holley two barrel carb on the way I am going to try on it.also took 2 1/2 pounds off the fly wheel back side
Ridlbox
Re: the 4a allmost ready to drop in
Post by Ridlbox »
Good looking motor let us know how it works out when you get the motor installed
That's my new goal 8)
jimcrazy
Post by jimcrazy »
will do ,, was hoping to get my wagon back on the road this week if the weather holds out. do a few 0-60 runs with the 3a so I have something to compare the swap to.
wow, that looks really nice jim. great work.
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Post by Mad_Marx »
Wow, nice job, were the internals rebuilt? Head work, cam, pistons, rings, etc? Looks great, can't wait to hear more about how it runs compared to the 3A.
Mad_Marx wrote:Wow, nice job, were the internals rebuilt? Head work, cam, pistons, rings, etc? Looks great, can't wait to hear more about how it runs compared to the 3A.
i put a 4a in my first terc and i honestly didn't notice any difference. for me, the weber was the single biggest 'bang for your buck' performance upgrade.
