1984 FWD abused
rer233
My tercel:: Multiple
Re: 1984 FWD abused
Post by rer233 »
rer233 wrote:dlb- Check out my post from a year and a half ago (I'd post a link, but can't- too stupid.) Just do a search on "MB switchover valve" and it'll come up. Sorry I never posted pics, but don't know how to do that either!
That's the one- I'll have to get my brother over here sometime to post some pics...
Tercel
My tercel:: 1984 FWD DLX
Re: 1984 FWD abused
Post by Tercel »
Messed with the car a bit today. It still spits a ton of black smoke. I have new gaskets for the carb but have yet to look into that process...
A few pics and sanding progress!
Re: 1984 FWD abused
that looks like a california emissions set up, that car must have had a long, hard road to it current owner.
Tercel
Re: 1984 FWD abused
Post by Tercel »
Progress
Re: 1984 FWD abused
i hate to tell you this now but you don't need to sand down to bare metal for a rattle can paint job. i usually don't even scuff the surface, although everything i've read recommends that for better adhesion of the new paint. i just wash, degrease, tape off, and give lots of light coats. i've painted lots of stuff that way and it's worked well for me. nice smooth finish that has stuck just fine.
however, with a car like yours that has already been rattle canned, some sanding is necessary to even out the high and low spots of the camo paint. i learned this while painting a VW van with my wife. it had been roughly rattle canned by the previous hippie owners and their old handiwork showed through our paint job. unfortunately, my wife was impatient and used 80 or 60 grit sandpaper on the bad spots so in the end, the sanded spots looked just as rough. oh well, live and learn. we sold it and the new owners really liked our paint job anyway.
here's said van. i added purple and pink pin stripes later that really made it 80's retro. wish i had pics of that.
viewtopic.php?f=9&t=5672&p=42092#p42341
Re: 1984 FWD abused
just found i do have some pics of the pin strips, i even posted some here.
viewtopic.php?f=9&t=6856&p=50954
and here are a few more
Tercel
Re: 1984 FWD abused
Post by Tercel »
Thanks for that. The Van looks quite nice with that paint and I like the color scheme and stripes too. Must have taken a looot of cans for a bigger vehicle like that
I think I did go a bit overboard sanding but my goal was to get it down to the original silver paint and grey primer. I did get down to bare metal in spots all over the car by accident though. I might even buy a can of primer and spray it on and sand it down just to get a bit of practice for when I paint something nicer.
Haven't been doing much with Tercel but it is getting close to the time to paint! I am thinking Olive Drab for fun, or maybe Silver like it was originally so that I can actually sell it when I need to. Of course black would be great too... :idea:
Tercel
Re: 1984 FWD abused
Post by Tercel »
I really want to address my steering problems soon. Of course this is the FWD Tercel wagon
The steering wheel itself has about 8 inches of play before the wheels turn, and it sits upside down when the wheel is straight.
When the front of the vehicle is lifted, the wheels can easily be pulled to rock left and right.
There is a gap on the rack and pinion that opens up when the wheel is turned all the way to the right. The 3 photos are all trying to show that
Maybe something is wrong or missing with the bracket over it? Not totally sure what I am looking at.
If I need to give up more pics or info I certainly will!
Insight would be very appreciated!
Re: 1984 FWD abused
i can't tell what i'm looking at but i think that's one of the rack bushings that holds the steering rack to the cross member. if there's any play (aka if you can wiggle the rack) at all, the bushing needs to be replaced.
it also sounds like your alignment is way out, and your inner and outer tie rods are suspect too. to check the tie rods, jack the front of the car up and push and pull on the tires, just like how the wheels turn when you steer normally. there should be no play, the wheel should not clunk at all. it should be tight in that position. if there is play, look at the inner and outer tie rods to see if either of them is the source of the play. if anything has play, it needs to be replaced.
here's a good write up on how to check and adjust the alignment at home.
viewtopic.php?f=7&t=2273
Tercel
Re: 1984 FWD abused
Post by Tercel »
Appreciate it, we were thinking it was the bushing and that confirms it. One of my tie rods is good and one shot.
I've put waay more cash into this than it is worth really (which shouldn't remotely be a surprise, oh well), but I suppose I may as well buy a rack and pinion kit for ~$140 to come with new tie rods via RockAuto. Otherwise it would be around $28 for the bushing and $12 tie rod at first glance. The boots are even more expensive and mine look awful. Going to read up for a day or two and decide
Re: 1984 FWD abused
there are generic boots that only cost about $10 each, you trim them to fit. the kit does not sound like a bad deal if you need everythign in it, but see what actually needs to be replaced and compare the cost of buying those with the kit cost. I rarely buy gasket kits anymore for this reason, usually you get a lot of gaskets you do not need.
lannvouivre
My tercel:: 2006 Pontiac Vibe
Re: 1984 FWD abused
Post by lannvouivre »
Petros wrote:I rarely buy gasket kits anymore for this reason, usually you get a lot of gaskets you do not need.
This is really good advice. I was told I should get the Toyota engine gasket kit for my 1ZZ overhaul. I now have about $50 worth of gaskets I didn't use. Actually it may be closer to like $75...anyway, otherwise I would have spent around $75 total and not almost $200. Regrets.
Re: 1984 FWD abused
3ac gasket kits are typically about $100-120, yet you can buy a head gasket, manifold gasket, valve cover gasket, seals and o-rings for about $25 from Rock auto, perhaps $45 from Autozone, and use a $5 tube of sealant on anything else.
if I can get the gasket out without damage, like the intake/exhaust gasket, I reuse it without issue.
