Zach's 1985 4WD Tercel Wagon
jimcrazy
Re: Zach's 1985 4WD Tercel Wagon
Post by jimcrazy » Sat Feb 13, 2016 10:32 am
i like to cut the brake off flush with the fitting and use a 6 point socket on them, if it twists off then replace the cly
lannvouivre
My tercel:: 2006 Pontiac Vibe
Post by lannvouivre » Sat Feb 13, 2016 11:08 am
I have a flare nut wrench that I'm using. dlb, I'll give that a try.
lannvouivre
Post by lannvouivre » Sun Feb 14, 2016 10:41 pm
I got the fuel pump bolted on in front of the spare under the chassis, but couldn't plumb it in because I didn't have the fittings I needed. Couldn't do the brake lines as my jack stands are tied up with Vibe brake diagnostics on my car. Can't wait to bolt on my snazzy mechanical fuel pump port block-off plate.
lannvouivre
Post by lannvouivre » Wed Feb 17, 2016 11:27 pm
With pathfinder springs and t-bird shocks in back, all-trac springs and strut housings up front (but sedan shocks, which are over an inch less shock rod length).
Tried to fix camber today enough that death might not seem so near when the car is driven. Got it more or less straight up and down. Test drove it and when I got home, it was back to positive camber deathmobile again (here is a diagram: \----/)
I think I have shown the issue before, but so you can share my pain once more:
Redid it, tightened the camber bolts "super freaking tight," and then lifted the front and pried on the two suspension components also involved (lower control arm bushing, ball joint). I think the part of the all-trac strut that the steering knuckle fits into is too wide for the Tercel knuckles. Could this problem be shimmed with some washers between the knuckle and the inside of the brackets?
Post by Petros » Thu Feb 18, 2016 12:17 am
that might work, but might be better to make a metal shim with two holes in the right place. It will fill the whole space, and have more area to compress against the steering knuckle. You can even make two shims, one for each side of the steering knuckle.
Also, using first gen MR2 front upper strut mounts should bring it down about 12mm, so it is not as high.
lannvouivre
Post by lannvouivre » Thu Feb 18, 2016 12:49 am
I'll try washers first to make sure the thickness is good. I admit I don't want to make shims where I need to drill two holes without messing up ;) I'll probably shape some when I make a bracket for my amp.
Speaking of which, I got my car's front brake lines replaced and no longer have the left front wheel locking up before all the others. Obviously, this doesn't make the badly misshapen rotor magically become normal again, but I have new parts on the way. Zach helped me bleed the brakes and was much more helpful than Mom ("my leg is tired.")
Forgot to mention that I got the dash reinstalled. The buzzer is dangling on the right side. IDK where to put it, and I really want to flatten it with a hammer because the noise it makes causes me to feel anger.
Post by Petros » Thu Feb 18, 2016 6:01 pm
if you do the brake up grade I outline over in the repair guides section, warped rotors will be a thing of the past. you go from the factory 11mm unvented solid front rotors to 25mm thick vented rotors. Personally I see no reason to waste money buying replacement brake parts that are inadequate even when new, the up grade parts do not cost much more, and you will not have to replace them again.
You can cut the buzzer off and toss it, I find it a very annoying sounds, and I do not need my car to buzz me when I am not wearing a seat belt. It gets mounted on the right end of the black steel angle that the glove box hinges get screwed to.
lannvouivre
Post by lannvouivre » Thu Feb 18, 2016 11:47 pm
My car, not the Tercel. My car had a failing front left brake line. The Tercel will be getting the upgrade soon, though, because it needed new brakes even before the rotors rusted "to death".
Wish I could steal the "key still in ignition" warning beeper from a newer BMW. Those things are very polite, although there's pretty much nothing else I like about BMWs aside from the automatic transmission controls. In fact, I mostly hate modern BMWs. That's a story for another day.
lannvouivre
Post by lannvouivre » Fri Mar 04, 2016 4:39 pm
Fixed the camber issues up front with some "shims" (washers) that make the all-trac struts fit the narrower Tercel steering knuckle brackets. The Tercel can now sit on the curb!
It's all ready to go get an alignment!
lannvouivre
Post by lannvouivre » Sat May 28, 2016 9:44 pm
Look pretty good for lipstick on a pig.
New battery, tray, and tie-down. AGM battery so I don't have do deal with acid leaks BS ever again.
Please ignore the wiring, I'm still working on a setup for my fuel pump so that I can get it to a dealer and align the sucker.
BaileySims
Post by BaileySims » Sun May 29, 2016 10:17 am
Looking good! Just noticed we have an identical stain under the fuel door. Mine is permanent though because u clear coated over it. Hahah
WAGON MAFIA.
Blood, sweat and beers.
lannvouivre
Post by lannvouivre » Sat Jun 04, 2016 4:57 pm
The paint is actually gone where it looks stained!
lannvouivre
Post by lannvouivre » Sun Jun 05, 2016 11:11 pm
Was bashing my face into the Tercel figuring out why the fuel pump relay won't work.
Turns out it's only going to be pulling 15A max, not 30A. The relay coil was too big of a load and still wasn't closing the arm.
My previous relay, an IDEC RH1B-U, was completely adequate, but lacks weather resistance. However, I will be able to move the Tercel now.
lannvouivre
Post by lannvouivre » Sat Oct 07, 2017 9:38 am
I figured out the fuel pump relay. I hadn't realized that it could be run in parallel, as my electrical courses didn't involve making circuits (just reading diagrams and following them). I also was a little confused about whether the voltage would choose one branch over the other for some reason. I don't know why this was a problem for me to understand at all, honestly, but I got it working correctly after asking my father if a circuit design I came up with would work.
Incidentally, this car is for sale. I don't think the wheels, steering wheel, electric fuel pump, or weber carburetor will be staying with it, though.
white_raven
My tercel:: 1987 toyota tercel 4wd
Post by white_raven » Sat Oct 07, 2017 10:01 am
Why are you getting rid of it??;
