a friend just sent this to me and it really helped me understand how the shifter changes gears so i thought i'd share it here.
manual trans graphic
Re: manual trans graphic
Seems a bit stuttery! It needs to slow down by quite a bit.
95 Camry Wagon, 170k
97 4runner, 275k
97 4runner, 275k
- Gottolovem
Very cool
Do ya think they really change colors like that
- BaileySims
it goes into second. it's first gear that is half cut off in the animation.
- BaileySims
Nice graphic. the action of the trans is often confusing because all of the gears are always engaged with each other and always turning. IT is the spline shaft that locks the appropriate gear to the main shaft (though the shift lever and shift forks) that causes the power transmission through the gear cluster to go from the input shaft, to the jack or side shaft, and back up to the output shaft.
