New Project 84 Tercel SR5 4X4
- tazoutaw
- My tercel:: 1984 Tercel SR5 4X4
When First Purchase had been sitting for over 6 years, due to timing belt.
- tazoutaw
Re: New Project 84 Tercel SR5 4X4
when she got home.
- tazoutaw
I had the motor pulled and complete rebuilt, new clutch, water pump, timimg belt, A/C compressor, etc...etc...
- tazoutaw
From sitting for so many years fuel went bad, It needed to be cleaned out.
- tazoutaw
All Struts were replaced with, KYB.
- tazoutaw
interior was pulled out and cleaned, also replaced padding with Dynamat.
- tazoutaw
Seats, replaced padding only.
- tazoutaw
After all above work done, first day back home, complete detail, was looking great! did not really care for the small 13 rims and tires.
- tazoutaw
Went and found me some 15x6 steelies and had them powder coated.
- tazoutaw
Sitting on new rims and tires 15x6 195/60/15 Hankook all Season Tires. Took out for a off road test drive, I was amazed on how it handled, it took all the hills with no problems
- tazoutaw
I had seen some T4WD online with Push Bars, liked the way they looked, went out and found one, had it custom mounted, can be removed anytime and add KC HID lights. This is how it sits at the present time, looking to add 2 inch lift/clearance, any ideas?
- Mark
Well holy crap. That's a hell of a lot of effort you put into it. I really like the new wheels. What are they from?
welcome to the forum, looks like a great project. Nice job.
suspention: front you can get '88-92' corolla all-trac front struts and springs (larger dia, more travel, stiffer spring, you have to change out the top mount). Also,k the same year GTS celica and corrola struts are the same, the stadard struts are similar dia so no advantage. Be careful not to go too much lift, it puts more angle on the front CV joints and causes them to wear out fast.
Rear: most go with pathfinder rear springs and t-bird shocks (more travel). I would consider cutting a coil off since it will lift the rear about 3" full length.
there are lots of threads on this topic, do a search.
How about some shots of how that push bar mounts. I like the look of that. Great job on your car.
that's awesome. great work on resurrecting the car. love all the pics.
for info on lifts, see #11 in the FAQ:
viewtopic.php?f=2&t=7442
