driftke70 wrote: Only issue with the car im trying to fix now is:
Webber choke idle
Slight hesitation at low speed low throttle input cruising
Get the aircon working again
Stop moisture getting in the headlights
If anyone has recommendations for the above would appreciate input.
there is an idle mixture screw on the webers, adjustment is easy, you set idle speed and screw mixture in and out until you get smooth idle.
You may have to change the low speed jets, there is a thread on the weber where everyone lists the jet and air mixture tube combinations that work well. You should have a place down under where you can order the jets you need after comparing what you have with what others have found work well.
can not help you with the air con, though there are also kits that will allow you to replace all the seals in the compressor, which at this age is likely what you need. the compressors are pretty reliable and ususally do not fail, other than the seals becoming old and leaky.
there is a process where you can take out the composite headlights, rinse out with pure alcohole to get moisture out, let dry. than apply sealant to all of the seams of the housing. If you have cracks on the lens than those need to be sealed too.
good luck
