New protection
- My tercel:: 1987
Here is what i made with a friend last week-end, it's a good protection when we ride big rises and descent.
<a href='http://www.imageshack.us' target='_blank'></a>
And here are my new tyres FEDIMA 175/65/14
For me the back end hits more often than the front...though more damage could happen to the front?
You could weld a pipe across the back also....would need to be a pretty good diameter to take a hit in the middle?
Good looking tires.
Good looking tires.
- My tercel:: 1987
Can someone help me to translate the different messages ?
It's really hard for me to understand all the things you say.
For the tyres the brand is fedima
web site : <a href='http://www.fedima.fr/fedima.html' target='_blank'>http://www.fedima.fr/fedima.html</a>
Thank you !
Thank you !
<a href='http://babelfish.altavista.com/' target='_blank'>http://babelfish.altavista.com/</a>Tercel Marseille wrote: Can someone help me to translate the different messages ?
Thank you !
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
only problem with babel is that if we misspell it won't recognize, could mistranslate, and it doesn't make grammatical sense once translated. Otherwise good.
bablefish doesn't translate from French to Eng very well...at least stuff from the French Tercel list. So it probably doesn't work so well the other way either.
Maybe there is a Canadian based translation site...they do a lot French vs Eng and so forth.
Désolé, Tercel Marseille, je supposais que vous n'avez pas eu besoin d'une traduction puisque vous parliez en anglais, mais voici une traduction, quoi qu'il en soit, pour les roues pièce. Tercel Marseille, d'où avez-vous obtenu ces 16-Trou 4 roues de modèle d'Au loin-Route du crochet X 100mm ? Étaient-elles nouvelles ? Quelle est la marque d'elles ? Que diriez-vous de du modèle ? Ou qui voiture ou camion vous les tirent de ? :unsure:
K-Business
- My tercel:: 1987
The rims are rims from Volskswagen golf 2. I bought them to a friend, 10 euros for one.
For the manufacture of the part, let's see :
<a href='http://www.forum-auto.com/sqlforum/sect ... 306718.htm' target='_blank'>http://www.forum-auto.com/sqlforum/sect ... 718.htm</a>
I hope you'll find what you want.
I want your headlights/ grille, and corner lenses heh.
Merci, Tercel Marseille. Maintenant il ferait frais si vous pourriez ajouter les chapeaux centraux des roues de sport de Tercel 7-Fente, cette parole TOYOTA sur elles, aux jantes de Volkswagen. D'ailleurs, Volkswagen est orthographié la manière que je l'ai juste orthographiée. Quelle année était le Golf Deux? Vous semblez idiot dans l'image où vous souriiez après enlèvement du butoir avant courant sur le Tercel. Vous êtes un type drôle ! :rolleyes: B)
K-Business
