After years of trying to get rid of a bad off idle hesitation, I found the problem and fixed it. Woo Hoo.
The carb (32/36) was missing the check ball for the accelerator pump. to get to it I had to drill out a plug which turned into a nightmare for awhile, it was very difficult for some reasons. I thought I ruined the carb because at one point I plugged the passage way from the fuel bowl to the accelerator pump during the drilling process and was looking at $92 for a new carb base. Several broken drill bits later I broke through to where the check ball was supposed to be. In an old box of left over carb rebuild parts I found 1 perfect ball bearing. I threaded the drill hole and cut a brass bolt, screwed it in with epoxy. My precious now drives like it was supposed to, no hesitation, just crisp clean acceleration. I have read that I am not the only one who has run into this defect. Passing on the info in case someone else has run into this problem.
Defective Weber Carb
Re: Defective Weber Carb
way to find a difficult problem. It is unfortuante that their quality control is so bad, and it is not an easy thing to check, that this is a regular problem. If you buy it new you could return it, but they would not likely honor a warranty claim after you drilled it out to find the problem.
you should definitely report your problem to weber. it might help them be more diligent about it in the future.
At the time all I could find out on the web was that it was a jetting issue. I went through all kinds of jet combinations trying to work it out. All the research said the carb was designed for 2.0 liter engine and ours is 1.5, so there supposedly wasn't enough manifold vacuum to signal the carb (32/36) properly. By the time I caught on to what the problem was, the warranty was gone I'm sure.
Did you purchase the Weber new or used? From eBay or an individual?
Did you contact the vendor or Weber?
I bought it new about 3 years ago and the car was down for repairs the past year. I have not contacted the vendor. I will have to look up which one.
I bought it from here. Kit K 740 http://www.redlineweber.com/carb-kits/auto/toyota/
- My tercel:: '86 SR5 6 speed
Thanks for sharing this, gatemaster, I suspect my car may have the same problem. Is there an easier way to tell if the accel pump ball is there? I don't suppose you took any pics of your fix, did you?
