Does anyone know of a source for these? I am trying to fit aftermarket wheels that are slightly thicker along with .25" spacers. Prolly need studs that are at least a half inch longer than stock. The local parts stores barely have stock oones, does anyone know where to get them? I'm thinking an online source. Dimensions are: M12 - 1.5 (about 1 inch worth of threads) . Crucial dimension is the 14.22" shank (splined part that is the interference fit into the hub). It can be a slightly bigger shank.
Thanks in advance!
Longer wheel studs
- My tercel:: '86 SR5 6 speed
Longer wheel studs
Re: Longer wheel studs
If you search Ebay for "toyota wheel studs" there are a fair amount that come up.
