Hi all, another little problem we've had ever since owning the turtle is that it pops out of 2nd when decelerating. My brother's '87 4wd wagon does it as well.
Is there a detent or something worn in the tranny, or could it be shifter related?
pops out of 2nd gear... easy fix?
Unfortunately that sounds like a bad clutch hub in the transmission. Just like the worn synchromesh that alot of us have, you would have to take the transmission apart to fix it. The shifter on these cars goes right into the transmission so there's no linkage to get messed up. It must be annoying to drive.
Will it only pop out when you first let out the clutch? My old tranny did that in 4th when it got bad, sometimes it would pop out and make a grinding noise while the shifter bounced back and forth. That tranny failure was explained away by the Redline oil that was black and thin as water, so it doesn't have to make us less confident about our trannies holding up. It might worry anyone who is using Redline synthetic though.
Odd. Is is normal to have a clunk from under the cab when putting on/releasing the throttle, especially in 1st, 2nd, and 3rd? Almost like the teeth aren't tight and slap against each other on the gears.
Actually the thing doesn't pop out of gear immediately after letting out the clutch. Seems to be more rev related, anything above 2000 rpm or so seems to make it pop out when slowing down. I don't really use the engine to brake much. Brake pads are cheaper than drivetrain wear...
And that clunking thing seems to be typical on these cars. you have to be pretty ginger with letting the clutch out or they bang...
The 2nd gear popout thing COULD be shift bushings, but, unfortunately, it's not likely.
I agree with 3A-C, the ODDS say, it's internal to the transmission.
And, I dunno about you guys, but, it's against my religion to open transmissions. I just pay the transmission shop for that stuff. Trannies are VERY busy on the inside, and AUTOMATIC transmissions SEEM to use alien technology. I just don't do it.
Regarding Typrus, and his clunking... THAT is the tranny mount... if you feel a clunk under your right foot, as you press the gas... it's the tranny mount. Whenever the tranny mount is replaced, you might as well replace the motor mounts, too (or else THEY start clunking... check to see if the bolts/nuts came loose, first). Don't let a tranny bang around TOO long, because the torsional/axial play can start fatiguing the sheet metal under your car, and/or screw with driveshafts, etc.
- Teddy
- Teddy
Hey 3AC...did you ever come to a conclusion on the Redline oil...did they ever analyze it?3A-C Power wrote: That tranny failure was explained away by the Redline oil that was black and thin as water, so it doesn't have to make us less confident about our trannies holding up. It might worry anyone who is using Redline synthetic though.
I can remember checking my trans one time when it had at least 1/2 Mobil synth oil /1/2 reg gear oil...all of it 85W90.....the oil was right at the lower edge of the opening and what ran out seemed real thin....which bothered me at the time.
It's possible that it separates and the thinner oil ends up on top?
