Setting the driver's seat back....
Takza,
I'm a bit unclear as to what you are asking...
To move the seat back, you simply lift the lever (under the front part of the seat), and push your butt into the seat. The seat should then move back.
Also, I dont think the seat can go back further than it's max back position. The front two mounting bolt brackets get in the way. It's been some time since I removed my seats and looked under them though.
With some cars, you can find a way to increase the seat travel. But maybe I've found an answer...I raised the front of the seat more..helps some.
