A little trick I use is to do as follows
Remove wheel
Remove brake drum
Remove the four nuts that hold the axle in place (easy access through the holes in the axle between the lug nuts)
Put the wheel back on but put the lug nuts on only about three turns
Pull the wheel out against the lug nuts suddenly, it acts like an impact and usually pulls the axle on the first or second try
Alright guys, i'm scared to ask...I have a noise
Re: Alright guys, i'm scared to ask...I have a noise
keith's preceding post is a pretty good trick as well (that keith - always the clever one!).
Comments by Petros - in Repair Guides:
http://www.tercel4wd.com/forums/viewtop ... ide+hammer.
Comments by sacwac - in Repair Guides:
MootsMan also has a few posts on this subject as well.
thanks I'll give that a shot......it does have a little play I'm sure with the right impact it'll pop right out. How is it held in? just with a compression type c-clip like the front axles?
Also I'll probably end up ordering new bearings and seals from rockauto....how fast is shipping usually?
- Neu
shipping isn't bad, up to a week. so order maybe 2 weeks in advance if you really needthem. Or you could just order overnight shipping if they have it available.
Couldn't wait that long...and the shipping cost was ridiculous. I got a bearing and seal set it locally for $32. And the wheel trick worked...a couple solid jars on the wheel and the axle popped right out. I just hope getting it back in will be as easy
Going back in is usually easy, assuming you clean out all the rust and grime.schmooot wrote:Couldn't wait that long...and the shipping cost was ridiculous. I got a bearing and seal set it locally for $32. And the wheel trick worked...a couple solid jars on the wheel and the axle popped right out. I just hope getting it back in will be as easy
If you continue to drive on bad bearings, thinking its a break or something, the axl will come out on it's own, without tools of any kind. I've learned what not to do. Don't lose a wheel at freeway speed, it's unsafe
-CASE
i have not tried this but a recent post brought it up
and it sounds good
flip the brake drum around and put the lug nuts on
but not tight
you want some travel for the drum when you pull it
it will slam against the nuts
just keep it up till the axel pops out
other than that a slide puller is needed
i have a homemade one
and it sounds good
but not tight
Remember to use the 5% discount when ordering with RockAuto. Search this forum and you will find a current one!
Thanks
Ashley
Thanks
Ashley
