Stupid question?
I believe that some tercels (Cali models?) came with an emissions control computer. Generally carbed cars do not need an ECU (engine control unit) to operate though; only fuel injected cars need an ECU.
Maybe someone can expand on your question and let you know exactly which tercels came with the emissions computer and what it does.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
I have seen, and taken apart the computer that comes in the CA models. In the manual, it's only listed for the 3AC engine, I have not checked my federal model tercel for it.
It's just about as simple as a computer can get, basic IO only... things like if switch A is closed, then I must close switch B.. sort of thing. It can't run without it. To give you an idea for what it controls, it's hooked up to the following parts:
Choke heater
vacuum switch
thermo switch
ox sensor
cold mixture heater
ebcv
vsv
fuel cut
It's usually located under the passenger side dashboard.
Choke heater
vacuum switch
thermo switch
ox sensor
cold mixture heater
ebcv
vsv
fuel cut
Not if you find an engine that came out of the same model type. Even if you get a different one, it will probably not be difficult to figure out how to connect things without the computer. Just buy a factory repair manual from Toyota for your tercel. It has wiring diagrams for all the different types.
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
