I thought that....according to my Bentley manual...the vac lines to the EGR & vac modulator were reversed.
Then yesterday, I happened to see the sticker under the hood that also shows the vac line routing...this shows that the lines weren't reversed after all...so I put them back again.
Went with the Toyota sticker over the manual.
Do all Tercels have a vac diagram under the hood???????
Vacuum line diagrams....
The Chilton's manual I have shows a vac diagram where the vac hoses are drawn as two lines...and like with one of those optical illusions...there is one hose that turns into the sides of two other hoses. I had to look several times to be sure.
So I used the Bentley manual thinking it was right...NOW I'll go for the sticker everytime.
- My tercel:: None
According to the sticker they do go to the same place...oh well...I'll eventually figure it <span style='color:blue'>ALL</span> out..... <_<
It means that they made some changes over time as the car was being made (in production) and might have changed the vac routing some?
