Weber carb install help
duragauge
My tercel:: 1986 Tercel 4WD SR5
Re: Weber carb install help
Post by duragauge »
cornell wrote: Thu May 06, 2021 10:16 am @Duragauge, is that a fuel pressure regulator of some kind on your fuel line into the weber?
Yes, it's a Holley 12-804 that's rated for 1-4 psi. It comes pre-set from the factory at 2.8 psi, which is just where I wanted it.
I originally thought I wouldn't need/want one, since I was getting 3.5 psi, but after a while I noticed my carb was getting too much fuel and gas was leaking out. The regulator seems to have fixed that.
Plus the pressure had been bouncing up and down due to the pumping of the mechanical pump, and the regulator has smoothed that out.
DirtyOregonKid
My tercel:: 1986 Tercel Wagon
Post by DirtyOregonKid »
@Duragauge Do you recall what nipples you're using on that regulator? I have the same one sitting on my bench. Thanks
Anyone doing this swap please hold onto the original carb as they work really well with a new carb kit put through them.
